Heat Transfer Coefs of My House
In summary: AlI helped a neighbor build a large addition on his home last fall, so that his daughter and 2 grand-daughters would have their own rooms. Recently, I have been helping him decide on how to insulate the place. We have been evaluating spray-in foam insulation (dense closed-cell, and lighter open-cell) and there are lots of variables even with that one choice. We built the whole addition out of full-dimension rough-sawn lumber with horizontally-boarded walls. I think we have settled on open-cell foam for the addition, though his house is insulated with that dense closed-cell foam.The amount of insulation in either case will depend on the
alhaggerty
I’ve measured the temperature in my house over time - after turning off the air conditioner. I have a time series of internal temperatures for a fixed outdoor temperature. Is it possible to calculate heat transfer coefficients of my house using this data? Is it possible to relate these heat transfer coefficients to “R values” used in residential construction? I would like to make a meaningful comparison of home insulation properties using this data.
Thanks for your help,
-Al
Science news on Phys.org
You can only do that if you assume that all the heat transfer is by convection. If the sun was shining there would be a significant amount of heat input from radiation. Unless the house is airtight there willl also be heat transfer caused by air moving in and out of the house.
Even if you did calculate a heat transfer coefficient, the value would depend on the wind speed and direction, so a single number would not be much practical use.
Any way to get a decent estimate?
Very tough problem. I helped a neighbor build a large addition on his home last fall, so that his daughter and 2 grand-daughters would have their own rooms. Recently, I have been helping him decide on how to insulate the place. We have been evaluating spray-in foam insulation (dense closed-cell, and lighter open-cell) and there are lots of variables even with that one choice. We built the whole addition out of full-dimension rough-sawn lumber with horizontally-boarded walls. I think we have settled on open-cell foam for the addition, though his house is insulated with that dense closed-cell foam.
Even if the place is well-insulated and all buttoned-up, can we calculate heat-loss/gain from solar input (dark enameled roofing material), thermal conductivity of siding, infiltration and solar gain from windows, etc? This stuff is an art, not a science, due to all the variables.
how about simply calculating some kind of "all-encompassing" thermal resistance?
You know:
T2 - T1 = Q x R
T2 is the temperature outside,
T1 is the temperature inside,
Q is the heat going into the house
R is the thermal resistance between the inside and the ousdie...
this R would be all-encompassing in that it takes into account all walls, ceiling, windows, doors and the occasional opening of doors, etc.
If you take T2 to be some kind of average outside temperature and T1 the thermostat temperature...that means that the air inside the house is always at the same temperature...and all the heat coming in is being taken away by the air conditioning...then, all you have to do it see how much energy the air conditioning uses and depending on its efficiency you can estimate how much heat went into the house...isolate R from that equation and determine it...
what do you think about this crude approach?
Thanks for the replies!
This overall thermal resistance idea is what I had in mind. I'm looking for a rough approximation of energy efficiency that can be used to compare different homes.
It occurred to me that I could measure the duty cycle of the air conditioner times its output capacity over a period of time to estimate heat rate (Q). Then a simple overall thermal resistance could be calculated knowing indoor and outdoor temperature.
I was also wondering how the time series temperatures could be used? I read in a different posting on Physicsforums.com that a time series could be used to calculate the free convection coefficient of a tent. In this example, it seemed heat was calculated from the initial conditions before the temperature was allowed to relax. Could this technique be used here?
Thanks again,
-Al
Nope: You can't even calculate how much heat your house is losing, since you don't know the specific heat! (unless you calculate/add it up for every item in your house individually!)
T2 - T1 = Q x R
How do you find Q?
That's much better, though as said that method doesn't differentiate between modes of heat transfer. You may want to try it after the sun has gone down on a hot night.
Even so, the thermal mass of the house (I live in a log house) can corrupt that data since really massive walls cool slowly. I would expect very different behavior compared to a sided conventional-construction framed-wall house with siding , and a more common southern design with framed-wall construction with brick veneer (rare here, up north). In some municipalities here, new construction with very shiny metallic metal roofing is forbidden, but it's OK if you use enameled metal roofing. I'd hate to be in the AC business up here and be asked to engineer some tightly-constrained efficient system with all those variables. The best I'd hope to do is to spec out an over-designed system that wouldn't cost the owners too much by running at less-than-capacity.
Actually, that's precisely the problem that this method solves. You're not waiting for the house to cool, you're holding it at a steady state and measuring the energy required to keep it at that steady state. So the specific heat is irrelevant.
That's why we use software to do it for us. :cool:
I guess it was not too clear, but in my previous post, Q the heat into the house, was meant to be equal to the heat absorbed by the A/C and equivalent to the energy used by the A/C (minus efficiency) ...giving that the thermostat is set always at the same temperature...
In any case, the problem could be discretized and perform some kind of integration over time...say every 12 hours...
12 hours during the day
12 hours during the night
12 hours during the next day
12 hours during the next night and so no
you could calculate average temperatures outside the house
and assume constant temperature inside
place a watt-o-meter on the A/C and know how much energy is consuming to keep the inside air at the same temperature and so this is the same as the heat going into the house since the air is being mantained at the same temp
For example, over two days and two nights, an average R could be calculated as
R = (1/4)x[ (Tday1 - Tin)/Qday1 + (Tnight1 - Tin)/Qnight1 +
(Tday2 - Tin)/Qday2 + (Tnight2 - Tin)/Qnight2 ]
or you could take only the days or whatever...you can play with what you want to take into account.
This, of course, is on a per-house basis since every house is different...then again, my neighborhood has 90 houses and just about every 5th is the same model...so, it might be useful, as mentioned by somebody else, to have the study for various types of constructions...
I should have realized that (or gone back and reread after getting to the end of the thread!)...yes, that makes sense.
Obviosuly it depends on the construction of the house (and UK and US conventions are rather different there) but in a brick construction most of the thermal capacity will be in the brickwork not in the air inside, and solar heating will create a significant temperature gradient through the thickness of the bricks.
I can certainly "feel" the effect of that in my own house. The front of the house faces west and is in full sun from about noon fill sunset. It is noticeable that on sunny days the inside temperature keeps rising for a couple of hours AFTER sunset, while the walls dump the heat into the air inside. (The UK climate is temperate enough that hardly anybody uses aircon for cooling.)
As Russ said, making a realistic computer model of this, and validating it against measurements, is a lot of work - which is why most people just use the empirical results in building codes and reguilations instead.
Don't forget to add all lighting, fridge, electronics and 100W per each human occupant.
Related to Heat Transfer Coefs of My House
1. What is a heat transfer coefficient?
A heat transfer coefficient, also known as thermal transmittance, is a measure of how easily heat can transfer through a material or interface. It is typically expressed in watts per square meter kelvin (W/m2K).
2. How is the heat transfer coefficient of my house determined?
The heat transfer coefficient of a house is determined by factors such as the type and thickness of insulation, the construction materials used, and the overall design of the house. It can also vary depending on the location and climate.
3. Why is it important to know the heat transfer coefficient of my house?
Knowing the heat transfer coefficient of your house can help you understand how well your house is insulated and how much energy is required to heat or cool it. It can also help you identify areas where heat may be escaping or entering, allowing you to make improvements for better energy efficiency.
4. How can I improve the heat transfer coefficient of my house?
To improve the heat transfer coefficient of your house, you can add insulation, seal air leaks, and consider using energy-efficient materials in construction or renovations. Proper maintenance and regular checks can also help ensure that the heat transfer coefficient remains optimal.
5. Can the heat transfer coefficient of my house change over time?
Yes, the heat transfer coefficient of a house can change over time due to factors such as wear and tear, settling of insulation, and changes in the surrounding environment. It is important to regularly monitor and maintain your house to ensure that the heat transfer coefficient remains at an optimal level.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
