Heat Transfer & Combustion: Estimate Pipe Heat Loss/m
In summary, In question a the outside temperature of a pipe carrying a process fluid at 300 °C is expected to cause a rate of heat loss of 171.78 watts per metre length. The thermal resistance of the pipe wall can be ignored due to the pipe's relatively low wall thickness.
Tiberious
73
<< Mentor Note -- poster reminded to use the standard Template >>
Question Three
A pipe of outside diameter 200 mm is lagged with an insulating material of thermal conductivity 0.06 W m-1 K-1 and thickness 75 mm. The pipe carries a process fluid at a temperature of 300 °C and the average temperature of the outer surface of the lagging is 45 °C.
(a) Estimate the rate of heat loss per metre length of pipe.
(b) Explain why the thermal resistance of the pipe wall can be ignored.
SOLUTION
Determine r_1
r_1=(200/2)=100mm or 1∙10^(-3) m^2
Determine r_2
r_2=(200/2+75)=175mm or 1.75∙10^(-3) m^2
r_(2 )/r_1 =(((200/2+75))/((200/2) ))
=1.75
ϕ= (2π∙1∙0.06∙(300-45))/(in (1.75))
=171.78 W per metre of pipe length
SOLUTION
The thermal resistance of the pipe wall can be ignored due to the pipe's relatively low wall thickness. Based on the below worked example we can see accounting for the mean pipe wall thickness the difference between the above and below answer's is 2.60pc.
If the wall thickness was to increase it would be prudent to use the logarithmic expression as this accounts for the change in area which becomes more important the thicker the pipe wall.
However, as no dimensions have been provided for the pipe wall thickness we can assume that the pipe wall is this and thus have a negligible effect impact.
Determining the width of the plate:
W=2πr_(mean )
r_(mean ) being the average of the radii given.
Determine r_(1 )
r_1=(200/2)=100mm
Determine r_(2 )
Hence
r_mean= (100+175)/2
= 137.5mm
Hence A_(mean ):
A_(mean )=W L
=2πr_mean L
=0.8649..
Applying Fourier's equation
ϕ= -kA(dT/dx)
We Get
ϕ= (kA_mean (T_1-T_2 ))/(r_2-r_1 )
= ((0.06)∙(0.8649)∙(300-45))/((175-100)∙10^(-3) )
=176.24..WThe percentage difference between this and the previous result is..
(176.24..-171.78)/171.78∙100pc
i.e.2.60pc
You can't go with some kind of mean radius; you have to integrate all the differentially thin sections to come up with the correct thermal resistance.
Sorry - I'm not clear on what you mean.
From the example we have been given. The approximation is just to show why the pipe wall thickness can be ignore in question a Is the answer sufficient?
Pardon me for any ignorance, I'm not entirely clear on this one.
For part (a) i got a significantly higher number than you did; I could well have made a computational mistake, did it quickly.
As for part (b) I thought the answer was either that the pipe wall is thin or the metal has a low thermal resistivity.
How have you calculated part a ?
Furthermore, as far as I can interpret the question for part b. It's asking for more of an explanation as to why we ignore the thermal resistance for part a.
Related to Heat Transfer & Combustion: Estimate Pipe Heat Loss/m
1. What is heat transfer and combustion?
Heat transfer is the process of transferring thermal energy from one object to another. Combustion is a chemical reaction that produces heat and light.
2. How do you estimate pipe heat loss?
To estimate pipe heat loss, you can use the following formula: Heat Loss = (Surface Area) x (Temperature Difference) x (Heat Transfer Coefficient). This will give you the amount of thermal energy that is lost through the surface of the pipe.
3. What factors affect pipe heat loss?
The factors that affect pipe heat loss include the surface area of the pipe, the temperature difference between the pipe and its surroundings, the type and thickness of insulation, and the heat transfer coefficient of the surrounding medium.
4. What is the heat transfer coefficient?
The heat transfer coefficient is a measure of how easily heat is transferred from one object to another. It is affected by properties such as the material and thickness of the pipe, the type of insulation, and the surrounding medium.
5. How does pipe diameter affect heat loss?
The larger the diameter of the pipe, the more surface area it has and the more heat can be lost. This is why pipes with larger diameters need thicker insulation to reduce heat loss.
