Heat transfer equation (temperature difference)
The discussion centers on the heat transfer equation mcΔT, where ΔT is typically defined as Tf - Ti. Participants clarify that ΔT can also be expressed as Ti - Tf when calculating heat loss from an object, such as copper. The equation mc(Ti - Tf) is used to represent the heat lost, while mc(Tf - Ti) indicates heat gained. It is emphasized that the negative sign in -mc(Tf - Ti) reflects energy leaving the system, but the magnitude remains positive since Tf is less than Ti in heat loss scenarios. Understanding the sign convention is crucial for accurately representing energy transfer in thermal systems.
MechaMZ
For the equation mc\DeltaT, i suppose \DeltaT should be Tf - Ti.
However, at what condition we should let \DeltaT be Ti - Tf?
I did come across a question which requires \DeltaT be Ti - Tf for a heat lost by an object.
eg,
heat lost by copper = heat absorbed by beaker & water
mc(Ti - Tf) = mbeakercbeaker(Tf - Ti) + mwatercwater(Tf - Ti)
I think perhaps we need to let mc\DeltaT as a positive value since it just a magnitude? however, the value is not the same(pretty close) if i let it be Ti - Tf.
Need help, thanks =)
anyone knows?
mc\Delta T=mc(T_f-T_i) is always the energy gained. The energy lost by the copper was then -mc\Delta T, which is equivalent to the other expression.
however, for the example above, why the initial temp and final temp is reversed?
Because -mc(T_f-T_i)=mc(T_i-T_f). Is this what you mean?
so we should write heat lost by copper as negative since the heat is released out, but the result of -mc(T_f-T_i) will still be positive right?
If you're saying that we should include the minus sign prefactor because we're considering the amount of energy leaving, but that the sign of -mc(T_f-T_i) is positive because T_f<T_i, I agree.
