Heat Transfer - finding rate of heat transfer
In summary: Not exactly. Express each of the temperature differences explicitly in terms of Q (just multiply both sides of your equation by R). Do this for each layer. Then add all the temperature differences together, and you will be left with only the inner and outer temperature values.
scrubber
A 0.8m high and 1.5m wide double pane window consisting of two 3mm thick layers of glass(k=0.78W/mK) is separated by a 10mm wide stagnant air space(k=0.026 W/mK). The convection heat transfer coefficients on the inner and outer surfaces of the window are 10W/m^2K and 35W/m^2K respectively. For a day when the room is maintained at 25oC while the temperature outdoors is 10oC, determine:
i) the steady rate of heat transfer through this double pane window, and
ii) the temperature of its inner surface.
Q=-k*A*ΔT/ΔX
Rth=ΔX/(k*A)
i)
Rth,glass=0.003/(0.78*0.8*1.5)*2
Rth,air=0.01/(0.026*0.8*1.5)
Rth,total=2.549 W/m^2.K
What should I do after this?
And is it correct to calculate Rth,air like this?
Thank you very much.
Looks fine. Now what about this convective heat transfer on the outer and inner sufaces ?
Rth,inner=1/(10*0.8*1.5)=0.0833W/m^2.K
Rth,outer=1/(35*0.8*1.5)=0.0231W/m^2.K
Like this?
Good. Now write and equation for the temperature difference across each of the layers (and for the inside and outside boundary layers) in terms of Q (which is the same for all the layers). Then add the equations together, and see what you get.
Chet
Chet
Q = (25-Tinner wall)/(Rth,inner) = (Tinner wall-TOuter wall)/(2.549) = (TOuter wall-10)/(Rth,outer)
Q = (25-Tinner wall)/(0.0833) = (Tinner wall-TOuter wall)/(2.549) = (TOuter wall-10)/(0.0231)
Is this what you mean?
Coming back to post #1:
I forgot to ask about the dimensions. If Q=-k*A*ΔT/ΔX and R is ΔX/(k*A) then what is the dimension of R ?
The about the calculation:
How do you get Rth,total from Rth,glass and Rth,air
Aren't they simply in series ? No suspicion about the values ? The biggest R is the air one: 0.01 divided by approx 0.03 can't yield approx 2.5 !?Post #3:
Why do you ask "Like this ?" ?
(Slow typist: Chet comes in and gives you the next step -- which in fact you already used when you added the R)
Chet
Related to Heat Transfer - finding rate of heat transfer
1. What is heat transfer?
Heat transfer is the movement of thermal energy from one object or substance to another. This can occur through three main methods: conduction, convection, and radiation.
2. How do you calculate the rate of heat transfer?
The rate of heat transfer can be calculated using the formula Q/t = kA(ΔT/Δx), where Q is the amount of heat transferred, t is the time, k is the thermal conductivity, A is the area of heat transfer, ΔT is the difference in temperature between the two objects, and Δx is the distance between the two objects.
3. What factors affect the rate of heat transfer?
The rate of heat transfer is affected by several factors, including the temperature difference between the two objects, the thermal conductivity of the materials involved, the surface area of heat transfer, and the distance between the two objects.
4. How does conduction differ from convection and radiation in terms of heat transfer?
Conduction is the transfer of heat through direct contact between two objects, while convection is the transfer of heat through the movement of fluids or gases. Radiation, on the other hand, is the transfer of heat through electromagnetic waves. Each method has its own unique characteristics and applications.
5. What are some real-life examples of heat transfer?
There are many real-life examples of heat transfer, such as when you hold a hot cup of coffee and feel the heat transfer from the cup to your hand (conduction), when you feel a breeze on a hot day (convection), or when you feel the warmth of the sun on your skin (radiation).
11K
