CKVEng
- 5
Hi Guys, this is my first post and I'd love a bit of help here, appreciated this may seem basic but it's been a few years since I did this last.
I have water in a stainless steel pipe (ID = 0.0381m, OD = 0.0411m) network of roughly 10m length, at 120 bar, roughly 50°C (+ or - 5).
This water is having 7kW of heat transferred into it by a cylinder and piston and I am going to assume that ALL of this heat is transferred directly into the water.
I need to work out whether it is practical for me to use a passive (or active ie with a fan) radiator type design to disperse this heat input into the air, or if I have to use a tank of cool water (assumed to be 20°C), to keep it within it's operating temperatures (90°C is the cut off maximum temperature) and if so, what are the sizes required?
Currently I am thinking about using a tank of cool water and passing the piping through this to cool it, but I need to know the required length of pipe in contact with the body of water to keep the temperature stable.
My mass flow rate (q) varies like a sine wave between 0 and 687.1 litres/minute (at 2hz) and I have been told to take an RMS value of this.
q RMS = √(x^2 + ∂^2)
Re=(μ.u.Dh)/μ
My RMS value was determined by my assumption that x = the average value ie the max/2
∴ x=343.55
∂= the standard deviation (?) which I was unsure about and assumed to be the same ie
∂=343.55
∴ RMS of flow rate = 485.9 Litres per minute = 8.0972 x 10^-3 metres^3 per second
Re=(ρ.u.Dh)/μ
where
ρ=998.2 (water at 20°C)
μ=1x10^-3 kg/ms
u=1.274.q/d^2=7.106500505 m/s
Dh=4.a.p= 0.00054585171 m
and
d= 0.0381 m
a= [itex]\pi[/itex] .(d/2)^2 = 0.00114009183 m^2
p= [itex]\pi[/itex] .d m
q= 0.008097227 m^3/second
∴ Re= 3832 = transient flow
this is incorrect as I know the flow to turbulent. Is this because I am using an incorrect RMS value?
How do I continue this solution to find my required pipe area or length?
Let me know if more information is required for the solution,
Any help will be massively appreciated!
Thanks,
Chris
Re=(μ.u.Dh)/μ
∴ x=343.55
∂=343.55
Re=(ρ.u.Dh)/μ
where
μ=1x10^-3 kg/ms
and
d= 0.0381 m
Thanks,
Chris
