nod32
- 14
I performed an experiment using a double pipe heat exchanger. Readings were taken at steady state.
Cold water entered the inner tube at 9°C, and its exit temp was 81°C. (flow rate was measured).
The outer tube contained steam at 133°C and this temperature remained constant. Condensate flow rate was measured.
i) q=U A ΔT(lmtd)
ii) q=m h[itex]_{fg}[/itex] (where hfg is heat of vaporization)
iii) q=m Cp ΔT(bulk)
Since the steam did not change temperature but condensed, there was latent heat transfer. q was calculated using ii). (result q=28kW)
I then calculated q using equation iii) applied to the cold water stream. (result q=59kW)
I don't understand why these two results are so far apart. In a perfect system, wouldn't they be equal?
