Heat Transfer in glass pane windows
In summary, the temperature of the wall will not be uniform, and heat transfer will take place through convection.
Gohar Shoukat
If the temperature of the wall is homogeneous i.e. the entire wall has the same temperature: T1 being the temperature of the left wall and T2 being the temp of the right wall, how will heat transfer take place? Can convection occur here? If yes then how will the bulk motion be set up?
I am attaching a picture of a glass pane window for clarification.
Assuming the left wall is the inner side (x = 0) and the right wall is the one in contact with the outside (x = 10 mm), heat conduction will occur from left to right, you can model this with Fourier's law. Then, you can model convection heat transfer from the glass to the outside air as a boundary condition for heat flux:
[tex]q'' |_{x=10mm} = \left. -k \frac{dT}{dx} \right|_{x=10mm} = h(T_2 - T_{\infty})[/tex]
Where h is the heat transfer coefficient for your system and T is the temperature of the ambient air outside.
thank you for your reply. I might not have fully defined the problem, it is air in between the two walls. The question therefore is, is convection possible or is conduction the only means of heat transfer through the air in between the two walls
Radiation is one means of heat transfer between the walls. If there is air in the middle and the air can move, then convection can happen, yes. If there is a solid connection between the walls, or if the gas in the middle can't move, heat can flow through the solid or gas too; that would be conduction.
Does it make a difference to you if the mechanism is radiant, convection, or conduction?
Of course, free convection of air will happen in the space between the two walls, but it won't have an effect on the heat transfer model, at least not in the x direction. It will still be just conduction. That is, at least at the level of BSL. You can, however, model the movement of air inside the middle space due to free convection, the temperature profile will have an effect on the velocity profile of air. You will find what you're looking for in section 10.9 of the second edition of Transport Phenomena by BSL.
Likes Gohar Shoukat
How will convection be setup when the walls have the same temperature at the top and the bottom? the air next to the right wall will have the same temperature at the top and the bottom, hence , density difference is virtually non-existent. or am i missing something?
As you move away from the hotter wall, density increases. This density difference will make the air start moving, and a laminar convection current will form inside the space. Both the physics and the modelling of the problem are discussed in more detail in the book I mentioned.
Sorry for the late reply. It has been a tough semester.
Likes Gohar Shoukat
Related to Heat Transfer in glass pane windows
1. How does heat transfer occur in glass pane windows?
Heat transfer in glass pane windows occurs through three main mechanisms: conduction, convection, and radiation. Conduction is the transfer of heat through direct contact between materials, such as when warm air inside the house comes into contact with the colder glass pane. Convection is the transfer of heat through the movement of fluids, such as the circulation of air between the panes of glass. Radiation is the transfer of heat through electromagnetic waves, such as when sunlight passes through the window and heats up the room.
2. Which type of glass is the best for preventing heat transfer?
The best type of glass for preventing heat transfer is low-emissivity (low-e) glass. This type of glass has a special coating that reflects heat back into the room, rather than allowing it to pass through the window. It also helps to block out harmful UV rays and can improve energy efficiency in the home.
3. How can I reduce heat transfer through my glass pane windows?
There are several ways to reduce heat transfer through glass pane windows. One option is to install double or triple pane windows, which have multiple layers of glass with an insulating gas in between. Another option is to add window treatments, such as curtains or blinds, which can help block out sunlight and reduce heat transfer. Additionally, using energy-efficient windows with low-e coatings can also greatly reduce heat transfer.
4. What are some common signs of poor heat transfer in glass pane windows?
Some common signs of poor heat transfer in glass pane windows include condensation or fogging between the panes, drafts or cold spots near the window, and higher energy bills. If you notice any of these signs, it may be time to consider replacing your windows with more energy-efficient options.
5. Can heat transfer through glass pane windows be reduced without replacing them?
Yes, there are some ways to reduce heat transfer through glass pane windows without replacing them. One option is to use window films, which can be applied to existing windows to improve their energy efficiency. Another option is to add weatherstripping around the window frames to reduce drafts and improve insulation. However, for long-term and more significant improvements in heat transfer, replacing the windows with energy-efficient options may be the best solution.
  • General Engineering
  • Materials and Chemical Engineering
