Heat transfer in polytropic process
In summary: Q=m(h2-h1). However, his answer was different from the answer key and he questions whether this approach is correct. He also poses several questions about the initial and final pressure, mass of water, work done, specific volume, final temperature, and internal energies.
panu36912
A piston/Cylinder arrangement of initial volume 0.025 m3 contains saturated water vapor at 180 degree Celsius. The steam now expand in a Polytropic process with exponent n=1 to a final pressure of 200 kpa while it does work against the piston. Determine the heat transfer for this process.
PVn=constant
I try solving this problem by using enthalpy.
Since state 1 is a saturated vapor, h1= hg=2778.16 kJ/kg
For state 2, its state is superheated vapor. By interpollating the value of h between 150 degree Celcius and 200 degree Celcius. I got the value of enthalpy equal 2829.79. Then i go for the heat transfer by using the formula, Q=m(h2-h1)
However, my answer is totally different from the answer key in the book. This problem is from Fundamental of Thermodynamic, Sontag and Borgnake, 8th edition, chapter 3, number 123.
The correct answer is 40.5 kJ .
This approach is not correct. Is the heat transferred equal to the change in enthalpy if the pressure is not constant?
What is the initial pressure? What is the final pressure. What is the mass of water in the cylinder? How much work is done in the poly tropic process? What is the specific volume in the initial and final states? What is the final temperature, and on what basis did you determine it? What are the initial and final internal energies?
Chet
Related to Heat transfer in polytropic process
1. What is a polytropic process?
A polytropic process is a type of thermodynamic process in which the pressure and volume of a gas change simultaneously, while the temperature remains constant. It is often represented by the equation PV^n = constant, where n is the polytropic index.
2. How does heat transfer occur in a polytropic process?
Heat transfer in a polytropic process occurs through conduction, convection, and radiation. Conduction is the transfer of heat through direct physical contact, convection is the transfer of heat through the movement of a fluid, and radiation is the transfer of heat through electromagnetic waves.
3. How does the polytropic index affect heat transfer in a polytropic process?
The polytropic index, n, determines the amount of heat transferred in a polytropic process. A lower value of n (less than 1) indicates a more efficient heat transfer, while a higher value of n (greater than 1) indicates a less efficient heat transfer.
4. What factors influence heat transfer in a polytropic process?
The main factors that influence heat transfer in a polytropic process are the initial and final states of the gas, the type of gas, and the polytropic index. Additionally, factors such as the surface area and thermal conductivity of the material through which heat is being transferred can also affect the rate of heat transfer.
5. What are some real-world applications of heat transfer in polytropic processes?
Polytropic processes are commonly used in various engineering and industrial applications, such as in refrigeration systems, gas turbines, and air compressors. They are also important in studying the thermodynamic behavior of gases and in the design of efficient heat transfer systems. Additionally, polytropic processes are relevant in environmental science, particularly in understanding the Earth's atmosphere and its temperature changes.
20K
15K
