Heat transfer rate from Mild steel bars to a chilled water tank issue
In summary, the conversation is about designing a conveyor to cool bars of freshly milled mild steel using a tank of water. The tank will be connected to a separate reservoir of water that will be cooled by a chiller and pumped in a cycle. The question is how much cooling and water capacity is needed for the tank and reservoir to chill the bars from 85°C to below 28°C in 144 seconds. The conversation also includes discussions on the lumped capacitance method, the Biot number, heat transfer coefficients, and thermal conductivity values. The calculation involves determining the optimal water temperature to remove the necessary amount of heat from the bars in the given time frame.
Xyimon
Hi all,
I am helping in designing a conveyor that takes freshly milled mild steel bars and submerges them in a tank of cooled water to reduce their temperature enough to to not damage the proceeding equipment.
The tank of water will be connected to a separate reservoir of water which will be cooled by the cooling equipment, and will then be pumped around in a cycle as the cooling equipment is not allowed near the milling machines.
The question is as follows:
Bars of mild steel with a radius of 25mm and a length of 1100mm, as transported into a tank of water, with a constant flow meaning that there will be 6 bars submerged in the water at any time, and will take a total of roughly 144 seconds to pass through the tank.
The tank of water holds 275L.
The bars will enter the water at roughly 85deg C, and need to be reduced to below 28deg C by the time they leave.
How much cooling (how large of a chiller) will need to be applied to the tank, and how much water will the separate reservoir need to hold to keep the water at optimum temperature, enough to chill the bars.
I believe that I need to evaluate whether the lumped capacitance method is applicable to the scenario by checking the value of the Biot number, but this is beyond my understanding, I have looked into it via wikipedia and some journals but I am struggling to understand which heat transfer coefficient (h) and thermal conductivity (ks) values to use for my scenario
So far I have worked out the following:
(Mass of metal in 1 bar = 17kg), (Specific Heat Capacity of Mild steel = 0.62j/kg/k or 620j/kg/k SO I use 620j/kg/k as its in Kg, correct?), (Temp change (T Final - T Initial) so 20deg - 85 deg = -65deg)
So we have 17kg x 620j/kg/k x -65 = -685100
Next, average heat loss per second per bar = -685100 / 144secs = -4757.64 (J/s or W) (Why is it J/s or W?)
And then finally, -4757.64 x 6bars = -28.546 K/watts
This answer is not of much use, instead I would need to determine the optimal water temperature for the cooling purpose, and the the optimal temperature depends on the time available for the cooling process.
Any help would be greatly appreciated.
Always carry your units through your calculations. What are the units of -685100 above?
Again, if you carry your units through the calculation, you'll see why the answer comes out J/s.
The result is -28.546 KW, not K/watt, which implies some sort of ratio.
What is your definition of the 'optimal' cooling water temperature? The only constraints you have specified is that six bars must be cooled from 85 C to below 28 C in less than 144 sec.
The bars must be <=28deg after the 144 seconds, so I need to work out what temperature the water needs to be kept at in order to remove that amount of heat from the bars in that period of time
I am having issues trying to work out a value needed to formulate the Biot number which is needed to work out what temperature a bath of water would have to be kept at to cool a specific amount of mild steel in an allotted period of time. (Quite a mouthful, I know)
K = 43w/(m.k)
Cp = 620 J/(Kg.K)
SpGr = 7.86ps OR 7860Kg/m3
Cylinder volume = 0.00216 m2
Cylinder Surface = 0.177 m2
Bi = h*Lc/k
h expressed in [W/m2/K] or equivalent units is heat transfer coefficient between the fluid (water) and the body (steel bar), but I cannot work this out for the life of me.
From this I am close to working out the Biot number, but to do so I need the unit surface conductance of my specific size of mild steel, which is worked out by the Thermal transmittance, Φ = A × U × (T1 - T2) ?
I believe I need to calculate the U-Value, which is where I get lost...
Regards,
Related to Heat transfer rate from Mild steel bars to a chilled water tank issue
1. How does the heat transfer rate from mild steel bars to a chilled water tank affect the overall temperature of the tank?
The heat transfer rate from mild steel bars to a chilled water tank is a crucial factor in determining the overall temperature of the tank. If the heat transfer rate is high, the tank will cool down faster, resulting in a lower overall temperature. On the other hand, a low heat transfer rate will result in a slower cooling process and a higher overall temperature.
2. What factors influence the heat transfer rate from mild steel bars to a chilled water tank?
Several factors can affect the heat transfer rate from mild steel bars to a chilled water tank, including the temperature difference between the steel bars and the water, the surface area of the steel bars, the material and thickness of the bars, and the flow rate of the chilled water.
3. How can the heat transfer rate from mild steel bars to a chilled water tank be increased?
To increase the heat transfer rate from mild steel bars to a chilled water tank, you can increase the temperature difference between the steel bars and the water, increase the surface area of the steel bars, use materials with higher thermal conductivity, and increase the flow rate of the chilled water.
4. What are the potential consequences of a low heat transfer rate from mild steel bars to a chilled water tank?
A low heat transfer rate from mild steel bars to a chilled water tank can result in the tank not reaching the desired temperature, leading to inefficient cooling processes. It can also cause the steel bars to overheat, potentially damaging them and reducing their lifespan.
5. How can the heat transfer rate from mild steel bars to a chilled water tank be accurately measured?
The heat transfer rate from mild steel bars to a chilled water tank can be measured using various methods, including heat flux sensors, thermocouples, and infrared cameras. These tools can provide accurate and real-time data on the heat transfer rate, allowing for precise adjustments to optimize the cooling process.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • General Engineering
