Heat transfer through a multi-layered wall
In summary: Bob were discussing the heat loss of a furnace wall which is made up of three layers with different thickness and thermal conductivities. They also considered the air gap between layers 1 and 2, as well as the temperature at the inner and outer surfaces of the wall. They used various equations to calculate the heat loss per square meter of the outside surface. Chet found an equation but was unsure how to remove the area to find the heat flux. Bob pointed out that the equation was missing the air gap resistance and the outside heat transfer coefficient. Eventually, they were able to find the correct equation and solve the problem. In summary, Chet and Bob discussed the heat loss of a furnace wall with different layers and an air gap, and used
Lieberkuhn
A furnace wall is made up of 3 layers:
1. 4mm layer of material with thermal conductivity of 52 W/m.K
2. 2mm layer of material with thermal conductivity of 20 W/m.K
3. 1mm layer of material with thermal conductivity of 3 W/m.K
There is an air gap between layers 1&2 with a thermal resistance of 0.16 K/W.
The temperature at the inner surface of layer 1 is 873.15 K
The ambient temperature outside layer 3 is 343.15 K
The heat transfer coefficient from outside surface to surroundings is 17 W/m^2 .K
Find the following:
1. Rate of heat loss per square metre of outside surface (heat flux)
2. Temperature at each interface of wall, including outside surface temperature.
h=q/ΔT[/B]
h = Heat transfer coefficient (in W/m^2 .K)
q = Heat flux (in W/m^2)
ΔT = Change in temperature (in K)
q=(kΔT)/L
k = Thermal conductivity (in W/mK)
L = Thickness of material (in m)
R=L/kA
R = Thermal resistance (in K/W)
A = Area (in m^2)
q=ΔT/[(L1/k1)+(L2/k2)+(L3/k3)]
ΔT = Change in temperature between outer surfaces (in K)
L1 = Thickness of layer 1 (in m)
L2 = Thickness of layer 2 (in m)
L3 = Thickness of layer 3 (in m)
k1 = Thermal conductivity of layer 1 (in W/mK)
k2 = Thermal conductivity of layer 2 (in W/mK)
k3 = Thermal conductivity of layer 3 (in W/mK)
Found the following equation but do not know how to remove A (area) to find q (heat flux).
3147.064q=28111200-8486.4A
Any useful hints would be much appreciated!
Problem asks for heat loss per square meter.
Let's see your calculations in detail. Your units on the air gap resistance are incorrect. Your equation for the heat transfer omits the air gap resistance and the outside heat transfer coefficient.
Chet
Related to Heat transfer through a multi-layered wall
1. What is heat transfer through a multi-layered wall?
Heat transfer through a multi-layered wall refers to the movement of thermal energy from one side of a wall to the other side. This can occur through conduction, convection, or radiation.
2. What factors affect heat transfer through a multi-layered wall?
The factors that affect heat transfer through a multi-layered wall include the materials used in each layer, the thickness of each layer, the temperature difference between the two sides of the wall, and the surface area of the wall.
3. How does the type of material affect heat transfer through a multi-layered wall?
The type of material used in each layer of the wall can greatly impact the rate of heat transfer. Materials with higher thermal conductivity, such as metals, will allow heat to pass through more quickly compared to materials with lower thermal conductivity, such as insulation materials.
4. What is the most effective way to reduce heat transfer through a multi-layered wall?
The most effective way to reduce heat transfer through a multi-layered wall is by using materials with low thermal conductivity, such as insulation, in the inner layers of the wall. Additionally, increasing the thickness of the wall and using reflective surfaces can also help to reduce heat transfer.
5. How does heat transfer through a multi-layered wall impact energy efficiency?
The rate of heat transfer through a multi-layered wall directly impacts the energy efficiency of a building. A wall that allows for high heat transfer will result in higher energy costs for heating or cooling the building, while a well-insulated wall with low heat transfer will lead to lower energy costs and increased energy efficiency.
