Calculate Energy Needed for Flexinol Contraction in Vacuum
In summary: T_{inf} - The temperature of the environment (ambient)Ra_{D} - Rayleigh numberNu_{D} - Nusselt numberh - Convective coefficient
Jai Sankar
I have a flexinol wire, and it has a resistance of 0.11 ohms/inch and it requires 4000mA for a 1 second contraction. I was wondering how much energy was required for a 1 second contraction and if I were to heat the flexinol under a vacuum, how much less energy would be required. The flexinol is a cylinder with a radius of 0.020 in and is 3 inches long, a density of 0.235 lb/in^3, and a specific heat of 0.2 cal/g * °C.
You have 3 inches of wire so total resistance is 0.33 ohms . Current is 4 Amps .
Power dissipated by a resistance is given by I2R Watts .
One Watt = One Joule / second - so how many Joules are needed for a 1 second ON time ?
(2)
Another calculation could tell you what voltage and Amp-Hour capacity a battery would need to be to supply required current and to give the required number of seconds ON time for your application .
(3)
I don't think that having wire in vacuum as opposed to air would make much difference to power consumption .
nb: Flexinol
How much heat would be lost to air rather than a vacuum?
Paint it flat black and energy loss is greater, polish it like a mirror, energy loss would be less. Infrared radiates pretty close to equally well in air or in a vacuum. Air does add a convection component, but for 1 second isn't long enough to establish any significant convection current.
in a vacuum it will do it's thing slower because the heat can escape the boundary layer faster. the air-to-wire boundary layer is like "R" in thermal insulation equations, thus heat will escape slower so temp will rise faster.
Natural convection is a tricky subject, but for a simple geometry like a wire in free air you can make some assumptions to make calculations a bit more manageable.
Your governing equations for heat loss per unit length would be:
  1. Convective Heat Loss: [itex]q'_c = \bar hπD(T_s - T_∞)[/itex]
  2. Radiation heat Loss: [itex]q'_r = επDσ(T_s^4 - T_∞^4)[/itex]
  • [itex]q'_c[/itex] - Convective heat loss
  • [itex]q'_r[/itex] - Radiative heat loss
  • [itex]\bar h[/itex] - Convective coefficient
  • [itex]D[/itex] - Wire diameter
  • [itex]ε[/itex] - Wire emissivity
  • [itex]σ[/itex] - Stefan-Boltzmann constant
  • [itex]T_s[/itex] - Wire temperature
  • [itex]T_∞[/itex] - Environment temperature
The dimensionless parameters used in the calculation of natural convection are where it gets a little tricky. You're looking for the convective coefficient but it depends on the temperature, so to start you'll guess a temperature and then calculate out the convective coefficient. You can follow an iterative process for estimating steady state temperature until you're able to balance heat loss with power input. So (guess temperature) → (calculate heat loss) → (compare to electrical power put in) → (repeat step 1).
To get the convective coefficient follow these steps:
  1. Calculate Rayleigh number: [itex]Ra_{D}=\frac{g\beta\left(T_{s}-T_{inf}\right)D^{3}}{\nu\alpha}[/itex]
  2. Calculate Nusselt number: [itex]\overline{Nu}_{D}=\left\{0.60+\frac{0.387Ra_{D}^{1/6}}{\left[1+\left(0.559/Pr\right)^{9/16}\right]^{8/27}}\right\}^{2}[/itex]
  3. Calculate convective coeffcient: [itex]\overline{h}=\frac{k}{D}\overline{Nu}_{D}[/itex]
where:
  • [itex]\beta=1/T_{s}[/itex]
  • Prandtl number: [itex]Pr = \frac{ν}{α}[/itex] (ratio of the kinematic viscosity and thermal diffusivity of air)
Related to Calculate Energy Needed for Flexinol Contraction in Vacuum
1. How is energy needed for Flexinol contraction in vacuum calculated?
The energy needed for Flexinol contraction in vacuum can be calculated using the formula: E = F x d, where E is the energy in joules, F is the force in newtons, and d is the displacement in meters.
2. What is Flexinol and how does it work?
Flexinol is a shape memory alloy made up of approximately equal parts of nickel and titanium. When heated, it undergoes a phase change and contracts, returning to its original shape when cooled. This process is known as the shape memory effect and is due to the rearrangement of its crystalline structure.
3. Why is vacuum used in the calculation of energy needed for Flexinol contraction?
Vacuum is used in the calculation because it eliminates any external factors such as air resistance or friction that may affect the movement of the Flexinol. This allows for a more accurate determination of the energy needed for its contraction.
4. What are some applications of Flexinol?
Flexinol has various applications in fields such as robotics, aerospace, and medicine. It is commonly used in actuators, motors, and sensors due to its ability to contract and return to its original shape with small changes in temperature.
5. Can the energy needed for Flexinol contraction in vacuum be accurately predicted?
Yes, the energy needed for Flexinol contraction in vacuum can be accurately predicted by using the aforementioned formula and taking into account the specific properties of the Flexinol being used. However, factors such as temperature and fatigue can also affect its performance and should be considered in the calculation.
  • Mechanical Engineering
