Height measurement on other planets
In summary: This surface is 3,396.2 km (2,110 mi) from the center of the planet, and the pressure at this surface is 115.6 Pa (1.156 mbar).[6]In summary, on Mars the zero elevation level is determined by an arbitrary atmospheric pressure, either 610.5 Pa or 115.6 Pa depending on the convention used. This is in contrast to Earth, where the sea level is used as the zero elevation datum.
Gustav S
If you measure the height of a mountain, you compare it's height with the sea level. But on let's say mars, how do you measure height when there is no sea to compare with?
For example: Olympus Mons is considered to be the tallest mountain or vulcano in the solar system, but what is the level on which you compare it with? There is no sea level or anything like that.
Thanks
Astronomy news on Phys.org
The choice of the zero mark for elevation is rather arbitrary. For Mars, it is currently determined by an equipotential surface.
From wikipedia: https://en.wikipedia.org/wiki/Geography_of_Mars#Zero_elevation
Zero elevation
On Earth, the zero elevation datum is based on sea level. Since Mars has no oceans and hence no 'sea level', it is convenient to define an arbitrary zero-elevation level or "datum" for mapping the surface. The datum for Mars is arbitrarily defined in terms of a constant atmospheric pressure.
From the Mariner 9 mission up until 2001, this was chosen as 610.5 Pa (6.105 mbar), on the basis that below this pressure liquid water can never be stable (i.e., the triple point of water is at this pressure). This value is only 0.6% of the pressure at sea level on Earth. Note that the choice of this value does not mean that liquid water does exist below this elevation, just that it could were the temperature to exceed 273.16 K (0 degrees C, 32 degrees F).[4]
In 2001, Mars Orbiter Laser Altimeter data led to a new convention of zero elevation defined as the equipotential surface (gravitational plus rotational) whose average value at the equator is equal to the mean radius of the planet.[5]
Related to Height measurement on other planets
1. How is height measured on other planets?
Height on other planets is measured using the same units as on Earth, such as feet or meters. However, the gravitational pull of the planet may affect the measurement due to differences in gravity.
2. Does height change on other planets?
Yes, height can change on other planets due to the varying gravitational pull. For example, a person who is 6 feet tall on Earth may be taller or shorter on a different planet depending on the strength of the planet's gravity.
3. Can you use a standard measuring tape to measure height on other planets?
No, a standard measuring tape cannot be used to measure height on other planets. Since the gravitational pull is different, the measurement would not be accurate. Specialized equipment is needed for precise measurements.
4. How does the height of mountains on other planets compare to those on Earth?
The height of mountains on other planets can vary greatly compared to those on Earth. For example, Mars has the largest volcano in the solar system, Olympus Mons, which stands at a height of 22km, much taller than Mount Everest on Earth at 8.8km.
5. Is there a universal standard for height measurement on other planets?
There is no universal standard for height measurement on other planets. Each planet may have its own units and methods of measuring height, depending on its gravitational pull and other factors.
