How High Was the Balloon When the Stone Was Dropped?
tremain74
I have a problem that says a stone is dropped from a balloon that is ascending at a uniform rate of 10 m/s. If it takes the stone 10 s to reach the ground, how high was the balloon at the instant the stone was dropped? The answer is 485m.
I am using the projectile motion. ay = -9.8m/s^2 for negative gravity. Vy = -9.8 + V0sin0. V0 is initial velocity. Sin0 is sin of theta. y = -4.9 t^2 + v0*t* Sin0.
ay = -9.8. Vy = -9.8 + v0*Sin0. y = -4.9*t^2 + v0*t*Sin0. By using formula of y, my solution was -4.9(10s)^2 + (10m/s)(10s)Sin0. I assumed that y was equal to 0. Since -4.9 is m/s^2 the answer would be -490m + 100m*Sin0. Therefore I assumeed Sin0 = 490/100.
Your "relevant equation" does not match your problem description.
Your equation is used for a situation where there is a horizontal component to the velocity of the object in free flight.
But the problem you stated does not presume any horizontal motion - nor would it be affected by horizontal motion.
When I solve the problem as stated by you, I do not get 485 meters, nor do I get anything similar to your calculation, nor do I use trigonometry.
At least not without specification. To use it, you must argue theta to be 90 deg., then it is correct. But it is a good idea to understand and define each element in the equation.....which you do not do. A free body diagram might be a better start .....
I agree (with @hutchphd) . When theta is taken as 90 degrees, then "Sin0" is 1 and the calculation in the second-to-last statement (of @tremain74 ) is correct.
But what is "Therefore I assumed Sin0 = 490/100." supposed to mean? Even if you are trying to force it to the answer provided (the apparently incorrect 485m), that statement would not be true.
Suppose an observer measured the time since the stone began to fall and it was 10 seconds.
The initial velocity of the stone in the opposite direction was 10 m/s and it stopped its ascent in 10/9.8 seconds.
That means the rock flies up 9.8*(10/9.8)^2/2=5.1m
From this point the stone falls in 10 seconds to the ground 9.8*10^2/2=490 m
That means the balloon was at 490-5.1=484.9 m altitude.
Likes pbuk
Sin0 being ##\frac{490}{100} >>1## , should itself be a warning.
Congratulations on reverse engineering the answer to work out what the question should have been!
The key lies in interpreting the phrase
In order to reach the answer of 485 m you need to interpret this phrase as "if the stone reaches the ground 10 s after it reaches its highest point" or "if the stone reaches the ground 10 s after its speed is zero".
As written by the OP, the answer is 390 m.
But whatever the original question that was set was, the answer clearly has nothing to do with trigonometry - all that is required is the right selection from the SUVAT equations.
Likes Babadag
FAQ: How High Was the Balloon When the Stone Was Dropped?
1. What factors determine the height of the balloon when the stone is dropped?
The height of the balloon when the stone is dropped depends on several factors, including the initial altitude of the balloon, the rate of ascent or descent of the balloon at the moment the stone is released, and the time elapsed since the balloon started its journey.
2. How can we calculate the height of the balloon when the stone is dropped?
The height can be calculated using the principles of kinematics. If you know the time it takes for the stone to hit the ground after being dropped and the acceleration due to gravity, you can use the equation: height = 0.5 * g * t^2, where g is the acceleration due to gravity (9.8 m/s²) and t is the time in seconds.
3. Does air resistance affect the calculation of the balloon's height?
Yes, air resistance can affect the calculation. The simple kinematic equations assume a vacuum, but in reality, air resistance will slow down the stone's fall, making it take longer to reach the ground. For accurate calculations, especially at higher altitudes, air resistance should be taken into account.
4. Is it possible to determine the height if the balloon is moving upwards or downwards when the stone is dropped?
Yes, it is possible. If the balloon is moving upwards, you need to add the additional height gained during the stone's fall to the initial height. If the balloon is descending, you subtract the height lost. The equations become more complex, involving the initial velocity of the balloon and the time of the fall.
5. What instruments or methods can be used to measure the height of the balloon directly?
Several instruments can be used to measure the height of the balloon directly, such as altimeters, GPS devices, and radar systems. These instruments provide real-time altitude data that can be used to determine the exact height at the moment the stone is dropped.
