Height of a rocket at a certain time
In summary, the rocket discarded a fuel canister by simply disconnecting it. It reached a maximum height of 345m and the canister hit the ground 8.39 seconds after disconnection.
moy13
During launches, rockets often discard unneeded parts. A certain rocket starts from rest on the launch pad and accelerates upward at a steady 3.20 m/s^2. When it is 260 m above the launch pad, it discards a used fuel canister by simply disconnecting it. Once it is disconnected, the only force acting on the canister is gravity (air resistance can be ignored).
How high is the rocket when the canister hits the launch pad, assuming that the rocket does not change its acceleration?
1. v^2 = v(0)^2 - 2g(y - y(0))
2. y = y(0) + v(0)t - (1/2)at^2
3. v = v(0) - gt
first i wanted to find the speed of the rocket at 260m by using equation 1. and solving for v. I attained 40.8m/s.
then I used this 40.8m/s as the initial velocity of the canister going up and v = 0 (speed of the canister at its maximum height) as the final velocity to find the initial height of the canister before it begins to drop. I attained 345m.
once i found this i wanted to find the final velocity of the canister before it hit the pad and used equation 1 again. I attained v = 82.2m/s.
after, i found the time it took the canister to hit the ground by using equation 3. I attained 8.39s.
finally, i used this time interval along with v(0) = 40.8m/s, y(0) = 260m, a = 3.2m/s^2 in equation 2. I attained 715m which is wrong according to the course website.
can anybody help me?
By your method there are 3 time intervals that need to be determined.
1. time to 260 m
2. time to canister max
3. time to free fall.
40.8 m/s / 3.2 yields your first time.
40.8 m/s / 9.8 yields your second time
345m = 1/2*9.8*t2 yields your third.
Add all 3 together and that put back into 1/2*(3.2)*t2 should yield your rocket height right?
Alternatively you can plug the 40.8 and the 260 into the initial conditions relating time, distance,and velocity and solve the quadratic
wow! Thank you so much LowlyPion. I did not notice how there were more than one time intervals.
Related to Height of a rocket at a certain time
1. How is the height of a rocket at a certain time calculated?
The height of a rocket at a certain time is calculated using the equation h = ut + 1/2at^2, where h is the height, u is the initial velocity, t is the time, and a is the acceleration due to gravity.
2. What factors affect the height of a rocket at a certain time?
The height of a rocket at a certain time is affected by various factors such as initial velocity, acceleration, air resistance, and external forces like wind or thrust.
3. How can the height of a rocket at a certain time be measured?
The height of a rocket at a certain time can be measured using various methods such as radar, lasers, and video tracking. These methods involve sending a signal or capturing images of the rocket and using mathematical calculations to determine its height.
4. Can the height of a rocket at a certain time be predicted?
Yes, the height of a rocket at a certain time can be predicted using mathematical models and simulations. However, external factors such as wind and air resistance can affect the accuracy of the prediction.
5. How does the height of a rocket change over time?
The height of a rocket changes over time as it experiences acceleration and deceleration due to external forces. It typically follows a parabolic path, reaching its maximum height and then descending back to the ground.
