Height of a stable droplet on a perfectly wetting surface
  • Thread starter Hak
  • Tags
    Spherical
Hak
709
56
The ceiling of a steam cabin is made of a perfectly wetting material. Since the temperature is slightly below the dewpoint, water droplets are forming on the horizontal ceiling. What is holding these droplets up there? Determine the height ##h## of the largest stable (just-not-dripping) droplet. Give this height ##h##, that is, the distance between the lowest point of the droplet and the ceiling, as a function of the water density ##\rho##, surface tension ##\alpha## and gravitational acceleration ##g##. Calculate ##h## numerically. Show all the passages conducting to symbolic formula.
I would assume that the droplet on the ceiling is spherical, since it is the shape that minimizes the surface energy for a given volume. The droplet is held by the surface tension force, which acts along the contact line between the droplet and the ceiling and is balanced by the weight of the droplet, which acts downward. Therefore:
$$2\pi \alpha r=\frac{4}{3}\rho g\pi r^3$$,
where ##r## is the radius of the droplet.
Solving for ##r##, I get:
$$2\pi \alpha r=\frac{4}{3}\rho g\pi r^3 \Rightarrow \ \alpha = \frac{2}{3}\rho g r^2 \Rightarrow \ r^2 = \frac{3}{2}\frac{\alpha}{\rho g} \Rightarrow \ r = \sqrt{\frac{3}{2}\frac{\alpha}{\rho g}}$$
The height ##h## of the droplet would be the distance from the lowest point of the droplet to the ceiling, which is equal to ##r \cos \theta##, where ##\theta## is the contact angle. Since the ceiling is perfectly wetting, the contact angle is zero, so I get:
$$h = \sqrt{\frac{3}{2}\frac{\alpha}{\rho g}}$$Plugging in the values of ##\alpha=0.0728 \ N/m##, ##\rho=1000 \ kg/m^3##, and ##g=9.81 \ m/s^2##, we get:
$$h \approx 2.7×10^{-3} \ m$$.
This reasoning seems too simplistic and incorrect to me. Where do I go wrong? Do you have any hint or insights? Thanks.
Hak said:
Homework Statement: The ceiling of a steam cabin is made of a perfectly wetting material. Since the temperature is slightly below the dewpoint, water droplets are forming on the horizontal ceiling. What is holding these droplets up there? Determine the height ##h## of the largest stable (just-not-dripping) droplet. Give this height ##h##, that is, the distance between the lowest point of the droplet and the ceiling, as a function of the water density ##\rho##, surface tension ##\alpha## and gravitational acceleration ##g##. Calculate ##h## numerically. Show all the passages conducting to symbolic formula.
Relevant Equations: /
Therefore:
2παr=43ρgπr3,
where r is the radius of the droplet.
The left side of this equation tells me that the droplet is held by its equator. Then the droplet is not a sphere. But the right side is volume of a sphere. --?
Yes, you are right. Do you have any hints on this?
IIRC the surface of the droplet will make an angle with the horizontal surface of the ceiling.
I cannot understand this. If the material is perfectly wetting, shouldn't the angle between the surface of the droplet and the horizontal surface of the ceiling be zero?
I understand that it would be zero if there were no weight of the droplet pulling it off.
Likes PeroK
So, I followed your advice by trying various approaches, but they all turned out to be very time-consuming and unlikely. They involve third- and fourth-degree equations that cannot be solved canonically, according to traditional methods: we need Cardano formulas, etc... If you can confirm to me that you all are sure that there is a simpler and more reasonable approach that does not involve these types of equations, I look forward to some advice to try other methods. Thank you.
Perfect wetting means the contact angle is zero, no exceptions. The shape will be like an upturned bell. It won't have constant mean curvature (https://en.wikipedia.org/wiki/Mean_curvature) because the pressure inside at the bottom will be more than at the top. (Edited)
Here, however, you only have to consider a droplet about to fall. When a droplet falls from, say, a dripping tap, what does it look like just before it becomes unstable?
@Hak, for the first part, you mention surface tension and gravity. No other forces you can think of?
I'm not sure, but I believe we have also to consider gravitational force and buoyant force. Is it correct?
You already consider gravity, correctly. Can you be more specific about buoyant force?
I gave a spur-of-the-moment answer. But, maybe, thinking it through, there is a downwards force from the pressure difference ##p_{\text{fluid}}-p_{\text{air}}## on the area of the horizontal cut.
That's not quite how I would put it. Considering the forces acting on the portion of the droplet below some level, we have gravity, surface tension (where the surface of the lower portion meets the surface of the upper portion) and air pressure.
When a drip is soon to fall, what can you say about the shape?
Which has a spherical shape?
That is rather past the point at which it becomes unstable. Or did you mean hemispherical?
Sorry for expressing myself wrongly. I meant inverted spherical cap.
It won’t be exactly a spherical surface. As I posted, it will be more bell-shaped. I'll see if I can figure out what it will be, but maybe spherical is near enough. More importantly, how big a part of a sphere? I.e. what do you think the steepest gradient will be?
What do you mean by "steepest gradient"?
The slope of the surface. It will be horizontal at the bottom and top (perfect wetting). It reaches a maximum somewhere in between. When the drop becomes unstable, what do you think the steepest gradient will be? Draw some pictures, study a slowly dripping tap.
This is the process I had adopted before your advice. I took a coordinate system with ##x## pointing to the right and ##y## pointing down and imagined the drop hanging from the ##y=0## plane. "Cutting" the drop horizontally at ##y##, the circumference of the bell at the cut is ##2\pi x## and the total force on the cut part is ##2 \pi x \alpha##, where ##\alpha## is the surface tension per unit length (a constant). The surface tension is parallel to the tangent and the total upwards force on the cut part has the component
$$F_y = -2\pi x \alpha \sin(\theta),$$
where ##\theta## is the angle (a negative value) of the tangent at ##(x,y)##.
What do you think? Obviously this is not the complete process, but I got here.
I was also thinking of employing energy considerations, but I don't think I have suitable knowledge here.
A teardrop?
Good.
Of course, that is just the force on that portion of the drop due to surface tension. There's the weight of the portion and air pressure from below.
Now, when it becomes unstable, there is a y value at which surface tension is no longer able to hold the drop in place. What does that suggest about ##\theta## at that latitude?
The volume ##V## of this part is the integral ##V = \int_y^{y_{\text{tip}}}\pi x^2dy##, where ##y_{\text{tip}}## is the
The mass of this volume is ##\rho V##, where ##\rho## is the density of water, and the force of gravity thus ##W = \rho gV##. Now, ##V## is an integral of ##x^2## versus ##y## and ##\tan(\theta) = \frac{\mathrm{d}y}{\mathrm{d}x} = y'##, so
$$\sin(\theta) = \frac{y'}{\sqrt{1+y'^2}}$$.
We have:
$$F_y = - 2\pi \alpha x\frac{y'}{\sqrt{1+y'^2}}$$.
I am not sure I understand this question, nor do I have in mind how to calculate air pressure from below. But are you sure that there isn't a downwards force from the pressure difference between air and fluid on the area of the cut?
Thanks.
Look at your expression for ##F_y##. If you increase the weight of the drop, how will ##\theta## change so as to try to hold things together? At what point will that no longer work?
Air pressure acting over a (horizontal) area.
Ok, I think I see your point. If we take the portion of the droplet below a cut as the body acted on, there are four forces:
  • pressure from air below
  • pressure from water above
  • weight of portion
  • surface tension
But I've just had a nasty thought… surface tension will contribute to the pressure in the droplet. I'll need to think about that more.
Perhaps what you mean is that the angle must vary according to ##- \frac{\pi}{2} < \theta < 0## because if ##\theta = 0##, then the force cancels and the weight maximises? Let me know if this is correct or if I still don't understand. Thank you very much.
  • weight of portion
  • surface tension
Yes, that is what I meant. Regarding your last statement...it is absolutely true. I really wouldn't know how to approach this kind of complication. That's why I thought of energy considerations. For this point I haven't the faintest idea.
Thank you again.
No. According to your expression for ##F_y##, what angle maximises its magnitude?
##\frac{\pi}{2}##, I think.
Right. When the steepest gradient reaches that the droplet becomes unstable. It cannot accommodate any more weight. So take the horizontal cut at that point.
If the radius there is R, what is the pressure in the water at that level?
Maybe ##p = \frac{\alpha}{R}##?
If you mean gauge pressure, yes. So what force does the water above exert on the lower portion?
A pressure force proportional to the depth of the water and the density of the water? Also, according to which you said, I think that the cohesive force between the upper part and lower part of the cutting boundary should be subtracted from the other downward forces, but I don't know how. Maybe as a constant multiplied by the area of the cut? Thanks.
  • #31
As discussed, it might not be as simple as that. But you don't need to go that route. You know the pressure there from the radius, so what is the force?
  • #32
Thanks. I would say ##F= \pi x^2 \frac{\alpha}{R}##. Correct?
  • #33
How is x different from R?
  • #34
I don't understand, what do you mean?
  • #35
Aren't they both the radius of the cut disc?
