MHB Heine-Borel Theorem in R^n .... Stromberg, Theorem 3.40 .... ....
  • Thread starter Thread starter Math Amateur
    Theorem
Math Amateur
MHB
I am reading Karl R. Stromberg's book: "An Introduction to Classical Real Analysis". ... ...
I am focused on Chapter 3: Limits and Continuity ... ...
I need help in order to fully understand the proof of Theorem 3.40 on page 104 ... ... Theorem 3.40 and its proof read as follows:
In the above proof by Stromberg we read the following:
" ... ... To see that $$S$$ is bounded, consider $$\mathscr{U} = \{ B_k (0) \ : \ k \in \mathbb{N} \}$$. Plainly $$\mathscr{U}$$ is an open cover of $$\mathbb{R}^n$$ and, in particular of $$S$$. Thus there is a $$k_0 \in \mathbb{N}$$ such that $$S \subset B_{ k_0 } (0)$$; whence $$\text{diam}S \leq 2 k_0 \lt \infty$$. ... ... "
I am troubled by the apparent (to me) lack of a rigorous argument to demonstrate that $$S$$ is bounded ...It appears to me that $$\mathbb{R}^n$$ is "infinitely large", that is unbounded ... and hence $$S$$ can be "infinitely large" and hence unbounded ... for example if $$S$$ is the $$x_1$$ axis of $$\mathbb{R}^n$$ then $$S \subset \mathbb{R}^n$$ and $$S$$ is unbounded ...
Can someone please demonstrate rigorously that $$S$$ is bounded ...
*** EDIT ***Just a thought after reflection ... even though open covers of \mathbb{R}^n and S may be "infinite" (in dimension) because S is compact it must have a finite subcover ... and hence S is bounded ... is that the correct argument?***************************************************************************************************Help will be appreciated ...
Peter
"Because S is compact it must have a finite subcover."
No, that is not correct. In fact, it doesn't make sense. To talk about a "subcover" you must first have specified a "cover". Are you talking about the one given in the argument, $B_k(0)$, the collection of open balls with center at 0 and radius k= 1, 2, 3, ...?
Notice that these balls are each contained in the next so that any point in the union of a finite number of them is in the largest, the largest "k". Since every point is S is some finite distance from 0 every point of S is in one of those so it is an open cover for S.
Since S is compact there exist a finite
subcover of that cover. There are only a finite number of such "$B_k(0)$" so there is a largest "k". S is covered by that single set so the distance between any two points in S is less than 2k.
Thanks for the help, HallsofIvy ... ...
You write:
" ... ... No, that is not correct. In fact, it doesn't make sense. To talk about a "subcover" you must first have specified a "cover". Are you talking about the one given in the argument ... "Yes, I was talking about $$\mathscr{U} = \{ B_k (0) \ : \ k \in \mathbb{N} \}$$ as given by Stromberg ... but I did not say so explicitly ... so strictly speaking ... yes ... what I said was not correct ... indeed reading literally ... it didn't make sense ... as you say ...
Thanks again ...
Peter
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
