BOAS
- 546
- 19
Consider a spin ##\frac{1}{2}## particle at rest in a B-field ##\vec B = B_0\vec e_z##.
(a) Find the Heisenberg equations for ##\hat S_x## and ##\hat S_y##.
(b) Obtain from the Heisenberg equations two decoupled second-order differential equations for ##\langle \hat S_x \rangle_{\psi}## and ##\langle \hat S_y \rangle_{\psi}## for a general state ##| \psi \rangle## of the particle.
(c) Solve the equations for a particle that initially (at t = 0) is in a state of ##S_x = \frac{\hbar}{2}##
For part (a) I have done the following;
##\langle \psi (t) | \hat B_S | \psi (t) \rangle = \langle e^{-\frac{i \hat H t}{\hbar}} \psi (0) | \hat B_S | e^{-\frac{i \hat H t}{\hbar}} \psi (0) \rangle = \langle \psi (0) | e^{\frac{i \hat H t}{\hbar}} \hat B_S e^{-\frac{i \hat H t}{\hbar}} | \psi (0) \rangle##
##B_H = e^{\frac{i \hat H t}{\hbar}} \hat B_S e^{-\frac{i \hat H t}{\hbar}}##
where the H and S subscripts correspond to the Heisenberg and Schrodinger pictures respectively.
The hamiltonian that I have is ##\hat H = - \gamma B_0 \hat S_z##
which leads me to the conclusion that my spin operators are unchanged in the Heisenberg picture.
for part (b) I use the Heisenberg equation of motion on both the ##\hat S_x## and ##\hat S_y## operators
##\frac{d}{dt} \hat S_x = \frac{i}{\hbar} [\hat H, \hat S_x] = \gamma B_0 \hat S_y##
##\frac{d}{dt} \hat S_y = \frac{i}{\hbar} [\hat H, \hat S_y] = - \gamma B_0 \hat S_x##
I then differentiate both again, and substitute the original equations into the result to find
##\frac{d^2}{dt^2} \hat S_y = -(\gamma B_0)^2 \hat S_y##
##\frac{d^2}{dt^2} \hat S_x = -(\gamma B_0)^2 \hat S_x##
These two equations are SHM equations with solutions of the form ##y = A \cos \omega t + B \sin \omega t ##
solving these I find that ##\hat S_y (t) = \hat S_y (0) \cos (\gamma B_0 t) - \hat S_x (0) \sin (\gamma B_0 t)## and ##\hat S_x (t) = \hat S_x (0) \cos (\gamma B_0 t) + \hat S_y (0) \sin (\gamma B_0 t)##
I don't really understand what the question is trying to get me to do here. Any guidance would be much appreciated.
