Heisenberg momentum uncertainty
An electron in a one-dimensional well of width 0.132 nm is analyzed for its energy, momentum uncertainty, and position uncertainty. The energy calculated for the n = 10 state is 2,160 eV, which is confirmed as correct. The uncertainty in momentum is derived using the relationship between position and momentum uncertainties, with the standard deviation of momentum equating to the momentum value in this scenario. The discussion highlights confusion regarding the application of the uncertainty principle and the role of the well's width in determining position uncertainty. Overall, the conversation emphasizes the importance of understanding quantum mechanics principles in solving the problem.
leehufford
An electron is trapped in a one-dimensional well of width 0.132 nm. The electron is in the n = 10 state.
a) What is the energy of the electron?
b) What is the uncertainty in the momentum?
c) What is the uncertainty in the position?
En = h2n2/8mL2
Delta(x)Delta(p) > hbar/2
The answers to this problem are in the back of our book, I got 2,160 eV for A, which was correct.
The book gave us a hint for part B: use Delta(x)Delta(p) > hbar/2, but here I have one equation with two unknowns. (I tried using 0.132 nm as delta(x) but that didn't give the right answer. Also, why would they ask for delta(x) in part C if it was given... so
I tried finding the momentum using
p = (1/c)sqrt(E2-(mc2)2). And my answer for momentum is the same as the book's answer for the uncertainty in momentum. I guess I can't see how to relate delta(p) to p. Also, why doesn't the length that the electron is trapped in count for delta(x)? Thanks for reading,
Lee
Hi!
Uncertainity (S.D.) in momentum and position can be found from the square root of the expectation value of the (p - pbar)^2 and (x-xbar)^2, respectively. Note that pbar is zero and xbar is a/2 in 1 dimensional infinite square well.
Yes, it happens that the S.D. of momentum is equal to momentum in this case. Can you guess the reason behind?
I'm not 100% clear on what you mean.. I've never actually taken a statistics class yet. The formula my book uses is
delta p = sqrt((p2)avg - (pav)2). If the average momentum is zero, and the formula reduces to:
sqrt(p2)avg, would I just use the momentum I found with relativistic dynamics...and that's why the standard deviation is the same as the momentum value? What does that mean physically? Thanks for the reply.
Lee
Just noticed I got moved, I didn't think homework problems from a modern physics class where considered introductory physics, but I guess I will post all of my questions here from now on. Sorry about that.
Never mind the moving to introductory. Perhaps they'll move it back once this is indeed about relativistic QM (it's not, I should think)..
We're more used to writing ##p=i\hbar {\partial \over \partial x}## in simple QM, where E=p2/(2m) if V=0. Same difference. But <p> = 0 for sure.
##\Delta p\Delta x \ge \hbar/2## is not an equation but something else (an inequality). Why they provide it as a hint is a mystery to me (at n=10 it's a lot more than ##\hbar/2##).
If your potential well is from 0 to L, I expect <x> to come out L/2 too... Look up the wave function and check. Then do <x2>. You will find that ##\Delta x \propto L##, so L does count!
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 32 ·
  • · Replies 18 ·
