Heisenberg's uncertainty principle question
In summary, the position and momentum of a 1.00 KeV electron were simultaneously determined, with a position uncertainty of 0.100 nm. Using the equation Δx⋅Δp≥ℏ2, the uncertainty in the electron's momentum was evaluated to be roughly 98% of its magnitude. However, after plugging in the correct value for p, which is 1[Kev]/c, the percentage of uncertainty was found to be 3.1%, rather than 98%. This discrepancy may have been caused by incorrect values being used in the calculation.
karkas
132
The position and momentum of a 1.00 KeV electron are simultaneously determined. If the position is located to within 0.100 nm, what is the percentage of uncertainty in its momentum?
(Arthur Beiser - Concepts of modern Physics, 3rd Part exercise 33)
[tex]Δx\cdotΔp≥\frac{\hbar}{2}[/tex]
[tex]Δx\cdotΔp≥\frac{\hbar}{2}\rightarrow \; Δp≥ \frac{\hbar}{2\cdotΔx}[/tex]
Given that Δx=0,100 nm, we can evaluate the uncertainty in its momentum Δp.
The momentum of the particle should be of roughly equal magnitude, and evaluating the fraction [tex]\frac{Δp}{p}%[/tex] gives me 98%, where the answer is 3,1 %. What did I do wrong?
What did you plug for p?
It should be p=1[Kev] /c where c is the speed of light.
Yep.
[tex]K=\sqrt{m_{0}^{2}c^{4}+p^{2}c^{2}}≈pc[/tex]
so
[tex]p=\frac{1,6\cdot10^{-16} J}{3\cdot10^{8} \frac{m}{s}}=0,533 \cdot 10^{-24} kg\cdot\frac{m}{s}[/tex]
and because [tex]Δp=\frac{1,05\cdot10^{-34}J\cdot s}{2\cdot 10^{-10}m}=0,525\cdot 10^{-24} kg\cdot \frac{m}{s} [/tex]
we get
[tex]\frac{Δp}{p}≈0,98[/tex]
Could I get a bumpity-bump 'cause these exercises are crucial for the finals?
You did not do anything wrong. The answer of 3.1% is correct. The 98% value you obtained is the percentage of uncertainty in the momentum, not the percentage of the momentum itself. The uncertainty principle states that the product of the uncertainties in position and momentum must be greater than or equal to a certain value, in this case, ħ/2. Therefore, the uncertainty in momentum cannot be equal to 98% of the actual momentum, as that would violate the principle. Instead, the uncertainty in momentum must be at least 3.1% of the actual momentum.
Related to Heisenberg's uncertainty principle question
1. What is Heisenberg's uncertainty principle?
Heisenberg's uncertainty principle, also known as the uncertainty principle or the indeterminacy principle, is a fundamental principle in quantum mechanics that states that it is impossible to simultaneously know the exact position and momentum of a particle with certainty.
2. Who developed Heisenberg's uncertainty principle?
Heisenberg's uncertainty principle was developed by German physicist Werner Heisenberg in 1927.
3. What is the mathematical formula for Heisenberg's uncertainty principle?
The mathematical formula for Heisenberg's uncertainty principle is ΔxΔp≥ħ/2, where Δx represents the uncertainty in position, Δp represents the uncertainty in momentum, and ħ is the reduced Planck's constant.
4. How does Heisenberg's uncertainty principle apply in everyday life?
Heisenberg's uncertainty principle only applies to the microscopic world of particles and has no noticeable effect in everyday life. However, it has implications in various technologies, such as electron microscopy and quantum computing.
5. Can Heisenberg's uncertainty principle be violated?
No, Heisenberg's uncertainty principle is a fundamental principle of nature and cannot be violated. It is a result of the wave-particle duality of particles in quantum mechanics.
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
