Heisenberg's Uncertainty Principle
In summary: It's just a number. OK?In summary, the conversation discusses Heisenberg's Uncertainty Principle and whether it applies to measuring anything in the observable universe. It is explained that the principle states that at the quantum level, the position and momentum of a particle cannot be known at the same time. However, the conversation also mentions that the principle has been misinterpreted and that the uncertainty is inherent in the way quantum mechanics describes the state of a system. The conversation also touches on the role of measurement in the uncertainty principle, but notes that it is not the whole story. Finally, the conversation mentions the value of h (Planck's constant) and its relation to the uncertainty principle.
X_Art_X
Hi Guys,
Newbie question from a layperson so please don't beat me up! :D
I know that Heisenberg's Uncertainty Principle relates to measurement/observation of
particles with regard to quantum physics.
My question is whether or not it applies to measuring anything in the observable Universe. i.e..:
A foot race between friends where pushing the button on a stopwatch causes some air to brush past the racers,
The measurement of voltage/current/impedance of a circuit where the multimeter's leads adds
impedance to the circuit or a drain on the current being measured.
I can't relate it to the measurement of time with a clock.
Might sound like a silly question, but is there an accepted answer?
Cheers, Art.
No, it doesn't apply.
Heisenberg's Uncertainty Principle states that at the quantum level, the velocity and the position of the particle can't be known at the same time.
He gave a relation with the Uncertainty in position and momentum (not with position and momentum).
[tex]Δx.Δp\ >=\ \frac{h}{2\pi}[/tex]
In the above relation the variables are the uncertainties.
Yes it applies to anything.
But there are precise mathematical rules behind it.
It is about "observables" and "compatible observables" and "incompatible observables".
For example, the positions of two particles are "compatible observables".
This means that you can measure both of them together with any precision.
Conversely, the poisition (x) and the velocity (vx) of a given particle are "incompatible observables".
Measuring one observable (x) with increasing precision, decreases the precision (knowledge, information) on the second (v).
"Incompatible" is not the right word.
One prefers to talk about non-commuting and commuting observables, in reference to the math behind that.
http://en.wikipedia.org/wiki/Uncertainty_principle
Remember I said layman! :D I don't pretend to understand math
If it applies to say, timing the observed angle of the travel of the Sun across the sky,
could it be explained how measuring the time between Sunrise and Sunset could affect the daylight time?
Or is that ridiculous?
What do you mean by "I can't relate it to the measurement of time with a clock"?
The photons you bounce off the hands of the clock affect the accuracy of the clock.
but not the time being measured as I understand.
A mechanical clock show the time by the position of something.
There is actually no other way!
So the principle applies also to time.
But there is more to that ... with some maths!
Well yes. You are still bouncing photons off the Earth to perform the measurement.
The measurement aspect of Heisenberg's Uncertainty Principle isn't the whole story. You might be interested in this..
http://www.livescience.com/18567-wacky-physics-heisenberg-uncertainty-principle.html
"In the early days of quantum mechanics, people interpreted the uncertainty relation in terms of such back-reactions of the measurement process," said physicist Georg Sulyok of the Institute of Atomic and Subatomic Physics in Austria. "But this explanation is not 100 percent correct."
Sulyok worked with a research team, led by physicists Masanao Ozawa of Japan's Nagoya University and Yuji Hasegawa of Vienna University of Technology in Austria, to calculate and experimentally demonstrate how much of the uncertainty principle is due to the effects of measurement, and how much is simply due to the basic quantum uncertainty of all particles.
Continues..
You've been misled by some of the popular "explanations" of the uncertainty principle, which try to explain it by saying that any measurement has to perturb the thing being measured. Although Heisenberg himself first explained it that way, as he and other quantum pioneers learned more and figured out what was really going on, they dropped that basically bogus explanation - and as so often happened in the history of QM, the popular press didn't notice and has kept on spreading misinformation that is now almost a century stale.
There are some real and interesting subtleties around how measurements disturb the system being measured (don't pass so quickly over CWatters's comment above - he's trying to get you to think about exactly what it means to "measure time"!), but these aren't part of the uniquely quantum nature of the Uncertainty Principle. So you can forget about them for a moment, they'll just get in the way.
Quantum mechanically, the uncertainty principle says that it is impossible for a quantum system to be in a state in which it simultaneously has a definite position and a definite momentum. It's not just that we can't measure both - it's that if the momentum is definite, whether known or not, then the position is not definite, and vice versa. This the fundamental quantum uncertainty, and it is inherent in the way that quantum mechanics describes the state of a system, whether measured or not.
There are two types of laymen...laypeople... those who are ilnumerate and those who aren't. If your mind "fuzzes" over when exposed to very small or very large numbers or simple algebraic equations, then you are ilnumerate. With practice and motivation, that is a problem you can fix, but we can't fix it for you, nor can we do much to dumb down our answers to overcome such disability.
The uncertainty principle is all about AxB = h/(2π). Where A and B are two measurements, or slightly more accurately, are the variation of two measurements. Now, if you understand that (in some tentative sort of way), then the FIRST thing you should be asking is:"What is the VALUE of h?". h÷(2π) is about
0.0000000000000000000000000000000001 (Jxs) (that's 1E-34). A Joule is the amount of energy required to accelerate a 1 kg object by 1 m/s² over a distance of 1 meter. Whether that is a lot compared to, say, the amount of force you would need to lift a hair from your shirt doesn't really matter. Why? Because of the 34 zeroes. A nanometer is 1E-9 meters. The point is, the scale where the above equation becomes significant are outside of your perception. An atom is say 0.1 to 0.01 nanometers; so h/2π is still a factor of 1E-24 below that. Still meaninglessly small. HTH. So since the observeable universe is quantum mechanical: yes it applies to the observeable universe, but no its not something that a macroscopic obsever (you or I) could ever notice directly.
X_Art_X said:
Hi Guys,
Cheers, Art.
There are hints here that seem to indicate a common misconception about the HUP. It appears that you are equating the HUP with some sort of issue with measurement accuracy.
You might want to start with what I had written earlier and see if you might think differently afterwards:
https://www.physicsforums.com/showthread.php?t=737543
Please also note that there are a number of reasons why "your friends" will not exhibit clear quantum effects and why applying the HUP to them is absurd.
Zz.
X_Art_X said:
Hi Guys,
X_Art_X,
Have you noted how many words in this single sentence are mathematical?
How could we answer without more reference to maths?
X_Art_X,
This may not be your OP question, but a point that Nugatory made deserves to be emphasized. It is almost existential. In physics, if there is no way to detect or measure something, than you can assume that it doesn't exist and see what the consequence is.
The statement that a precise position and momentum cannot exist is very profound. It explained some things that could not be understood before.
Related to Heisenberg's Uncertainty Principle
What is Heisenberg's Uncertainty Principle?
Heisenberg's Uncertainty Principle is a fundamental principle in quantum mechanics that states it is impossible to know the exact position and momentum of a particle at the same time.
Who is Heisenberg and how did he discover this principle?
Werner Heisenberg was a German physicist who, along with other scientists, developed the theory of quantum mechanics. In 1927, he published a paper introducing the uncertainty principle based on his research on the behavior of subatomic particles.
How does the uncertainty principle affect our understanding of the physical world?
This principle challenges our classical understanding of the physical world, where the position and velocity of an object can be determined precisely. In the quantum world, the act of measuring one property of a particle will inevitably affect the measurement of its other properties.
What are the implications of the uncertainty principle in technology?
The uncertainty principle has had a significant impact on technology, especially in the development of electronic devices. It has allowed for the creation of transistors, which are essential components in modern electronics. It also plays a crucial role in technologies such as MRI machines and lasers.
Are there any exceptions to the uncertainty principle?
There are no known exceptions to the uncertainty principle. It is a fundamental aspect of quantum mechanics and has been supported by numerous experiments and observations. However, there are ways to minimize the uncertainty, such as using more precise measurement tools and techniques.
