I Helmholtz entropy of ideal gas mixture is additive?
The discussion centers on the Helmholtz potential of mixtures of ideal gases, as presented in Callen's textbook. The first claim asserts that the Helmholtz potential of a mixture is the sum of the potentials of its individual components, while the second claim states that this additivity does not apply to other thermodynamic potentials expressed in their natural variables. The user expresses confusion about how to demonstrate this additivity and questions the implications of the second claim, particularly regarding the nature of thermodynamic potentials. They also clarify a previous mix-up between Helmholtz free energy and entropy, indicating a desire for further understanding of related thermodynamic equations. The conversation highlights the complexities of thermodynamic properties in ideal gas mixtures.
EE18
In his classic textbook, Callen remarks that
(1) The Helmholtz potential of a mixture of simple ideal gases is the sum of the Helmholtz potentials of each individual gas:$$ F(T,V,N_1, ... ,N_m)=F(T,V,N_1)+ ··· +F(T,V,N_m). $$
(2) An analogous additivity does not hold for any other potential expressed in terms of its natural variables.
I have labelled the claims (1) and (2). I am not sure about either. For the first, I have tried to proceed as follows (all equations are from Callen's second edition and all 0 subscripts are with respect to some reference state of an ideal gas):
We begin by noting that for a single component of the mixture (in the volume ##V## of the overall gas per the given formula in this problem) we have from (3.34) that
$$F_i(T,V,N_i) = U(T,V,N_i) - TS(T,V,N_i) $$
$$= c_iN_iRT -T\left(N_is_{i0} + c_iN_iR \ln (T/T_0) + N_iR \ln(V/V_0) - N_iR(c_i+1) \ln (N_i/N_0) \right)$$
Now for the mixture we have
$$F = U - TS $$
$$\stackrel{(1)}{\equiv} (\sum N_j c_j)RT - T\left( \sum N_js_{j0} + (\sum N_j c_j)R \ln (T/T_0) + (\sum N_j) R \ln(V/V_0) -R \sum N_j \ln(N_i/N)\right).$$
where (1) is from (3.39) and (3.40) (i.e. from the definition of ##F## that for a mixture of ideal gases (i.e. in the same vessel), we form ##U-TS## for ##U## and ##S## of the entire system).
I can't see how to go further in terms of identifying one with the other
But even supposing I can show that, what does claim (2) mean? Is Callen saying that there is no other thermodynamic potential (partial Legendre transform of the energy ##U##) which is such that this additivity holds in terms of natural variables? Obviously ##U = \sum N_jc_j RT## which is additive, but I guess this isn't a counter example since ##T## isn't a natural variable of ##U##?
Science news on Phys.org
I think you mean Helmholtz free energy, not Helmholtz entropy.
I think it might help to consider the following questions:
What is Gibbs theorem for the partial molar properties of the components in an ideal gas mixture?
What is the equation for the partial pressure of a gas component in an ideal gas mixture in terms of Nj, R, T, and V.
What is the equation for the partial molar entropy of a gas component in an ideal gas mixture as a function of temperature and partial pressure?
What is the equation for the partial molar Helmholtz free energy of a gas component in an ideal gas mixture in terms of temperature and partial pressure?
Oy, yes I did mean Helmholtz (free) energy -- I've been thinking too much about the entropy because of another question I had clearly! If you do get the chance, that question is here. I've been very grateful for your insights on thermodynamics as I work through Callen, both now and in the past!
For these:
"The contribution to a property of a mixture of ideal gases is the sum of the properties that each component gas would have if it alone were to occupy the volume V at temperature T"
and
##P_i = N_iRT/V.##
I don't think either of these is relevant for this particular question though?
For these:
I believe I included the answer to both in my OP. Indeed, it seems like the problem I'm having is massaging a sum (on ##j##) over the first equation in my OP to be of the second equation's form, hence why I'm not sure if I'm making a mistake at the outset.
Maybe something like this: $$F_j((T,V,N_j)=N_ju_j(T_0,v_0)+N_jC_{v,j}(T-T_0)-$$$$T\left[N_js_j(T_0,v_0)+N_jC_{v,j}\ln{(T/T_0)}+N_jR\ln{\left(\frac{V}{N_jv_0}\right)}\right]$$where ##T_0## and ##v_0## are the temperature and molar volume in a reference state, and ##s_j## and ##u_j## are the molar entropy and molar internal energy of species j in the reference state. Then substitute $$\ln\left(\frac{V}{N_jv_0}\right)=\ln\left(\frac{V}{x_jNv_0}\right)=\ln\left(\frac{V}{Nv_0}\right)-\ln{x_j}$$
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
