bob5bob
- 1
Hello everyone,
I am a recent horticulture graduate and as such, I take a long time figuring out physics problems.
I hope I could trouble you guys for a possible solution to my problem. I am making an rotary atomizer that is pneumatically powered and need to find out how fast i can make it spin with a max 100psi airflow. The turbine part is 40mm in diameter and has four half circle blades. It is contained in a shaped case that is two parts which are mirror images of themselves, each side has a vent which is 6mm by 6mm and a entry hole for a 5mm inside diameter pipe. The disc is out side the case and is 80mm in diameter. Basically I am just trying to figure out an equation for this that allow me to take air pressure and calculate RPM of the disc. Any help would be appreciated.![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
