Help calculating this limit please
Lambda96
Calculate limit of ##\frac{1}{n+1} |\frac{x-1}{\xi}|^{n+1}## as ##n \rightarrow \infty##
none
Hi,
I have problems with task b, more precisely with the calculation of the limit value:
By the way, I got the following for task a ##f^{(n)}(x)=(-1)^{n+1} \frac{(n-1)}{x^n}##
Unfortunately, I have no idea how to calculate the limit value for the remainder element, since ##n## appears in the exponent. I tried it with L'Hôpital's rule and then get ##\Bigl( \frac{x-1}{\xi} \Bigr)^{n+1} \log(\frac{x-1}{\xi})## and if I now form the limit, it would be ##\infty## or not?
Why would you apply l’Hopital? It is useful for cases when you have expressions where both numerator and denominator tend to zero.
You should focus on what is being exponentiated: ##(x-1)/\xi##. What are the possible values of this?
Thanks Orodruin for your help 👍, I hadn't thought of that, so the amount in the parenthesis is less than 1, which makes the limit at infinity zero.
Can be equal.
haruspex said:
Can be equal.
Yes, but the prefactor 1/(n+1) still goes to zero so the limit is still zero. Of course, for the proof to be valid the argumentation should be the correct one though.
Quite so, but I was leaving that to the OP.
