Help converting kJ/(kg*degC) to Btu/(lbm*degF)
  • Thread starter Thread starter AnotherParadox
The discussion focuses on converting kJ/(kg⋅°C) to Btu/(lbm⋅°F) using dimensional analysis. The initial attempt yielded an incorrect conversion factor due to a misunderstanding of temperature change relationships. It was clarified that a change of 1°C corresponds to a change of 1.8°F, which is crucial for accurate conversion. The correct approach involves recognizing that ΔT(F) = (9/5)ΔT(C), leading to the conclusion that 1 kJ/(kg⋅°C) equals 0.238846 Btu/(lbm⋅°F) when the conversion factors are properly applied. This highlights the importance of understanding temperature change conversions in thermodynamic calculations.
AnotherParadox
[/B]
Show that 1 kJ/(kg⋅°C) = 0.238846 Btu/(lbm⋅°F) using dimensional analysis and the given conversion factors:
1 Btu = 1.055056 kJ
1 kg = 2.2046226 lbm
T(°F)=1.8⋅T(°C)+32
[/B]
1 Btu / 1.055056 kJ =1
1 kg / 2.2046226 lbm = 1
1.8⋅Δ°C / Δ°F=1
(1 kJ/(kg°C)) ⋅(1 Btu / 1.055056 kJ) ⋅ (1 kg / 2.2046226 lbm) ⋅ (1.8⋅Δ°C / Δ°F) ≈ 0.842661 Btu/(lbm⋅°F)
I have no idea how this is wrong but it is according any conversion table I've seen.
Please help, I need to know what I'm doing wrong.
Thank you
Hello.
Check the part where you're converting the temperatures.
Likes AnotherParadox
TSny said:
Hello.
Edit: I think I know what I'm doing wrong but still need help, ready below this post.
How is it wrong ? I've been staring at it for hours. The change is 1.8 or 9/5 ..
100 C = 212 F
0 C = 32 F
The slope is 9/5 or 1.8 with a y intercept of 32. In the analysis wouldn't this be multiplying by a factor of 1.8 since I'm going from inverse C to Inverse F.. I may be confusing myself with the methodology here idk
Sorry for double post
So I think I understand what's wrong
The "change in F" and "change in C" is what I'm comparing
It makes sense that a change of 1.8 F only results in a change in 1 C so I can change my conversion factor... but how do I show this logic rigorously or in math terms? In other words.. how do I show more work stating from the T(F) = 9/5 T(C) + 32 results in 1.8 Δ°F = 1 Δ°C
AnotherParadox said:
1.8 Δ°F = 1 Δ°C
This is correct. But this is not what you used in your conversion in the first post.
Right. Once I replace the conversion factor the answer is correct.
However I'm still unsure how to take the information
and conclude
1.8 Δ°F = 1 Δ°C
in a way other than just mental reasoning ... how do I apply math notation to this to show something rigorous? Perhaps I'm concerned out of illusion .
Consider an arbitrary initial temperature and an arbitrary final temperature. So,
Tfinal(F) = 9/5 Tfinal(C) + 32
Tinitial(F) = 9/5 Tinitial(C) + 32
Subtract the two equations.
I'm not sure I follow. Won't the 9/5 stay with the T(C) ?
Yes. So you will get ΔT(F) = 9/5 ΔT(C). Now interpret this.
Suppose you consider the case where the temperature change is 1 Co. The interpretation of the equation is that it tells us that this temperature change of 1 Co will be a change on the Fahrenheit scale of 9/5 Fahrenheit degrees.
The confusion might be coming from the fact that the 9/5 has hidden units. The 9/5 has units of Fo/Co. So, when we consider a temperature change of 1 Co, we have
ΔT(F) = (9/5 Fo/Co) ⋅ (1Co) = 9/5 Fo.
So, 1 Co is equivalent to 9/5 Fo.
The suppressed units is what got me. Makes perfect sense now
  • · Replies 29 ·
22K
