Help creating a vertical vector
In summary, to extend the vector $\lgroup\rgroup$ symbols vertically to include the $3$ and $0$, you can use the pmatrix environment and the detexify tool. This will give you a better-looking result, but the appearance may vary depending on the font being used.
karush
MHB
3,269
how do you get the
vector $\lgroup\rgroup$ symbols to extend vertically to include the $3$ and $0$
\(\displaystyle \lgroup \begin{array}{c} 3 \\ 4 \\ 0 \end{array} \rgroup\)
so that is looks like this
https://www.physicsforums.com/attachments/1088
Re: LaTeX example forum
karush said:
how do you get the
Code:
\begin{pmatrix}
3\\
4\\
\end{pmatrix}
dwsmith said:
Code:
\begin{pmatrix}
3\\
4\\
\end{pmatrix}
that looks better but it still is not the group symbol.$\begin{pmatrix}3\\4\\0\end{pmatrix}$
You can always use detexify. However, I think the different look may be related to a specific font being used.
Check out this thread for the link to detexify:
http://www.mathhelpboards.com/f26/need-help-identifying-certain-latex-characters-5223/
$\pmatrix{r_1\cr
r_2\cr
r_3\cr
r_4\cr
r_5}$
OK the {} will stretch if the rows are enough to do so.
FAQ: Help creating a vertical vector
What is a vertical vector?
A vertical vector is a mathematical representation of a quantity that has both magnitude (length) and direction, and is oriented in a vertical direction.
How is a vertical vector different from a horizontal vector?
A vertical vector is oriented in a vertical direction, while a horizontal vector is oriented in a horizontal direction. This means that their magnitudes and directions are perpendicular to each other.
How do I create a vertical vector?
To create a vertical vector, you must first determine the magnitude and direction of the quantity you want to represent. Then, you can use this information to construct a vector with a vertical orientation, using mathematical operations such as addition, subtraction, and multiplication.
What is the importance of vertical vectors in science?
Vertical vectors are important in science because they allow us to accurately represent and analyze quantities that have a vertical component, such as force, acceleration, and displacement. They are also crucial in fields such as physics and engineering, where precise measurements and calculations are necessary.
Are there any real-life examples of vertical vectors?
Yes, there are many real-life examples of vertical vectors. Some common examples include a pendulum swinging back and forth, a ball being thrown into the air, and a rocket taking off into space. In each of these cases, the quantity being represented has a vertical component, and therefore can be described using a vertical vector.
