Help double-checking my work on acceleration
In summary, the conversation discusses a physics problem involving two objects racing on a track, where one has a higher initial speed and the other has a non-zero acceleration. The conversation also includes calculations to determine which object would win the race based on the length of the track. The conclusion is that for a short race, initial speed is more important, but for a longer race, acceleration plays a larger role.
AFSteph
Hello! I'm new here and I would just like to make sure my work is correct.
Question as listed in my textbook:
"Go to http://www.fearofphysics.com/Xva/xva.html
Start your first object at 1 m, give it a speed of 2.5 m/s, and an acceleration of 1 m/s squared.
Start your second object at 1 m, give it a speed of 8 m/s, and an acceleration of 0 m/s squared.
Hit "Go!" to see which object wins the race. Which won, the first or the second object?
What factor ended up being most important in the race, speed or acceleration? If the race track was longer, which would have been more important, speed or acceleration? Explain your answer."
Note: You guys don't have to go to the site. It's just a simple flash game. At those settings the second object wins because it's a very short race. (You can just click here to see http://www.fearofphysics.com/cgi-bi...1=1&object2=redtruck&x2=1&v2=8&a2=0&mode=wrap
Formula given by my textbook for finding velocity and distance of an accelerating object in which v[itex]_{o}[/itex] is the initial velocity.
v = v[itex]_{o}[/itex]t + at
d = v[itex]_{o}[/itex]t + [itex]\frac{1}{2}[/itex]at[itex]^{2}[/itex]
In this case speed is more important, as seen by the second object winning the short race presented by the game. However, if the race were longer, let's say it lasted for 100 seconds, the first object would have caught up to the second object 11 seconds in and by the end of the race the first object would have traveled 5250 m while the second would have gone a mere 800 m, losing by 4450 m. The longer the race is, the acceleration causes a greater and greater disparity between the distances traveled by the two objects.
My calculations
Finding the time when the two objects had traveled the same distance. (Solving for t)
d = v[itex]_{o}[/itex]t + [itex]\frac{1}{2}[/itex]at[itex]^{2}[/itex] = r x t
d = 2.5 m/s x t + [itex]\frac{1}{2}[/itex]1 m/s[itex]^{2}[/itex] x t[itex]^{2}[/itex] = 8 m/s x t
d = 2.5t + [itex]\frac{t^{2} }{2}[/itex] = 8t
d = 5t + t[itex]^{2}[/itex] = 16t
t[itex]^{2}[/itex] = 11t
t = 11 seconds
Check: (First object) 2.5m/s x 11 seconds + [itex]\frac{1}{2}[/itex]1 m/s[itex]^{2}[/itex] x 11[itex]^{2}[/itex] = 88 meters traveled
(Second object) 8m/s x 11 seconds = 88 meters traveled
Finding the distances traveled by the two objects in 100 seconds.
First object: 2.5m/s x 100 seconds + [itex]\frac{1}{2}[/itex]1 m/s[itex]^{2}[/itex] x 100[itex]^{2}[/itex] = 250 + 5,000 = 5,250 meters traveled
Second object: 8m/s x 100s = 800 meters traveled
Sorry for the length! It's been a long time since I've done any algebra and I just want to make sure I did this right. I hope it's easy to follow my calculations.
You know the acceleration!...What are you trying to solve for?...You haven't mentioned anything in your question about finding anything!...The question is just :
Which won, the first or the second object? What factor ended up being most important in the race, speed or acceleration? If the race track was longer, which would have been more important, speed or acceleration? Explain your answer.
If the race is for a short period of time, the initial velocity plays more important role because vaguely speaking acceleration get much time to set in. If the race is for a longer period of time, the acceleration of the object would create a disparity in the distance traveled (ever increasing with time).
You solved for overtaking point (11 s), which clearly gives you the above explanation.
Short Period<11 s
Long Period>11 s
Edit: you can easily calculate borderline length of short track and long track from overtaking point, which you have. It is 88 m.
@NihalSh
I just wanted to make sure that my calculations were correct. Like I said, I haven't done algebra in a long time and was kind of unsure of myself. So I guess what I wrote is right?
Thank you for talking the time to comment! I really appreciate a second opinion :)
AFSteph said:
@NihalSh
yes, calculations were right. :smile:
Hello! Welcome to the community and thank you for reaching out for help with your work. I have reviewed your calculations and they appear to be correct. Your explanation of the importance of speed and acceleration in the race is also accurate. Just to add a bit more context, speed is how fast an object is moving while acceleration is how quickly the object's speed is changing. In this case, the second object has a higher initial speed, which gives it an advantage in a short race. However, as you calculated, the first object's acceleration allows it to catch up and eventually overtake the second object in a longer race. Great job on your work and keep up the good work!
Related to Help double-checking my work on acceleration
1. What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a vector quantity, meaning it has both magnitude and direction.
2. How is acceleration calculated?
Acceleration can be calculated by dividing the change in velocity by the change in time. The formula for acceleration is a = (vf - vi) / t, where vf is the final velocity, vi is the initial velocity, and t is the time interval.
3. What units are used to measure acceleration?
The SI unit for acceleration is meters per second squared (m/s^2). Other common units include feet per second squared (ft/s^2) and kilometers per hour squared (km/h^2).
4. What is the difference between positive and negative acceleration?
Positive acceleration occurs when an object is speeding up, while negative acceleration (also known as deceleration) occurs when an object is slowing down. The direction of the acceleration vector determines whether it is positive or negative.
5. How is acceleration related to force?
Acceleration is directly proportional to the net force acting on an object. This means that the greater the net force, the greater the acceleration. This relationship is described by Newton's second law of motion, which states that force equals mass times acceleration (F = ma).
