[Help] Expansion of air or due to formation of water vapour?
In summary, the popping of the cork is due to the increase in pressure from both the air above the water and the water vapors.
dibilo
47
Hi all,
I recently encountered this scenario.
I placed a (1 litre) glass bottle with water (about half filled) that is corked up near my stove.
My wife was cooking and the cork suddenly popped.
We discussed this over dinner and I said that it was due the air in the bottle that has become heated and expanded.
My wife said it is due to some water turning into water vapour and cause the build up in pressure. I thought that make sense but I am interested to know what really happens in that scenario. Is it mainly due to air expansion or water turning into water vapour that has caused the popping of the cork?
I vaguely remember what I learned in college about the bombardment of molecules but many years has passed and much has been forgotten.
Please help us solve this so the debate over dinner table can end. :) Thanks.
I think there is not much to debate. If you heat up the bottle both the pressure of the air above the water and the pressure of the water vapors will increase.
You cannot say than only one of them popped the cork. It may be possible that one contribution will be larger than the other.
One of the tables in http://en.wikipedia.org/wiki/Vapour_pressure_of_water" shows you how the vapour pressure of water changes with the temperature.
Around room temperature, the vapour pressure is not a lot but, of course, at 100C, the vapour pressure is 1 Atmosphere (100kPa). Warming water just from 20C to 30C changes the vapour pressure from 2.3kPA to 4.2kPa (an excess pressure in the bottle of 1.9kPa - assuming the cork was pushed in at 20C).
The change in air pressure for the same temperature change would be 100kPa times the temperature ratio (in K - because you have to refer it to absolute zero, -273K)
That would be 100X303/293 - or 103.4kPa- another 3.4kPa
The total excess pressure would be 1.9 + 3.4 = 5.3kPa or about 1/20 Atmosphere. Enough to push out a loose cork.
For a bigger temperature increase, the vapour pressure would start to dominate.
Thank you both for you fast reply.
My wife and I are both Science lovers so whenever sure things happen, we will be excited and confused as well due to our limited knowledge.
We have learned something interesting today.
Thanks again!
I would like to offer some insight into this scenario. The popping of the cork in this situation is most likely due to a combination of both air expansion and the formation of water vapor.
When the bottle is placed near the stove, the air inside the bottle is heated, causing it to expand. This expansion of air creates pressure inside the bottle, which can lead to the cork popping off. However, as your wife suggested, the formation of water vapor also plays a role in this scenario.
As the water inside the bottle is heated, some of it will evaporate and turn into water vapor. This water vapor also adds to the pressure inside the bottle, contributing to the popping of the cork.
In summary, both air expansion and the formation of water vapor contribute to the pressure buildup inside the bottle, leading to the popping of the cork. I hope this helps to settle the debate at your dinner table.
Related to [Help] Expansion of air or due to formation of water vapour?
1. What is the expansion of air?
The expansion of air refers to the increase in volume of a given amount of air as its temperature increases.
2. How does the formation of water vapour affect air expansion?
When water is heated, it evaporates and forms water vapour. This water vapour takes up more space than the liquid water, causing the air to expand even further.
3. What are the factors that affect the expansion of air?
The expansion of air is affected by temperature, pressure, and the amount of water vapour present in the air. As temperature and/or pressure increase, the air expands. The presence of water vapour also contributes to the expansion of air.
4. Why is the expansion of air important?
The expansion of air is important for various reasons. It is a fundamental concept in thermodynamics and is essential for understanding weather patterns. It is also crucial in the operation of engines and other machinery that rely on heated air for power.
5. How is the expansion of air measured?
The expansion of air can be measured using various instruments such as a thermometer, a barometer, and a hygrometer. These instruments measure temperature, pressure, and humidity, which are all factors that affect the expansion of air.
9K
  • Mechanics
