Help explain the following formula? (Young's doubles slit)
In summary, x/L is different by the sine, but if you consider small angles the sine can be approximate by the tangent and then by x/L.
KneelsBoar
Member advised to use the homework template for posts in the homework sections of PF.
Hello, I'm currently writing a report on young's double slit experiment, and I've used the equation nλ/d = x/L and I was wondering if someone could explain the question? I know how it works, and how to solve for lambda, but could I have some more detail into why it works?
For example, why can Sin θ be substituted by x/L in this case? Would they not give different values?
I appreciate the help.
Hello KneelsBoar. Welcome to PF !
Can you supply a sketch with those quantities included?
So, in the limit L>>d you have this equation for young double slit constructive interference:
dsin θ = nλ
Sin θ = nλ/d
Now, if λ/d is small or in other words d is much larger than lambda also sin θ is small
If the sine is small it can be approximate by the tangent that is x/L if by x you mean the vertical distance between the center and the fringe
So yes... x/L is different by the sine, but if you consider small angles the sine can be approximate by the tangent and then by x/L
Example: use the calculator to find sin (2) and tan (2) ( i mean 2 degrees not 2 radians)
As the value of x (in mm) is very small as compared to the screen distance L (in m) the angle theta is very small and for small angles sine of that angle is approximately equal to the angle measured in radius.
Alternately for very small angle the arc length and the perpendicular is nearly same and thus theta = arc length/ radius = perpendicular/ hypotenuse
FAQ: Help explain the following formula? (Young's doubles slit)
What is Young's double slit formula?
Young's double slit formula is a mathematical equation that describes the interference pattern produced by two closely spaced, parallel slits when light passes through them. It was first proposed by English physician and physicist Thomas Young in 1801.
How is Young's double slit formula derived?
The formula is derived from the principles of wave interference, which state that when two waves overlap, they produce areas of constructive and destructive interference. In the case of Young's double slit experiment, the two slits act as sources of coherent waves that overlap and create an interference pattern on a screen placed behind them.
What are the variables in Young's double slit formula?
The variables in the formula are:
  • d: the distance between the two slits
  • L: the distance from the slits to the screen
  • λ: the wavelength of the light used
  • θ: the angle between the central maximum and the location of the interference pattern on the screen
How does Young's double slit formula explain the interference pattern?
The formula explains the interference pattern by taking into account the distance between the slits, the distance from the slits to the screen, and the wavelength of the light used. The interference pattern is created by the overlapping of the wavefronts from the two slits, resulting in areas of constructive and destructive interference on the screen. The formula calculates the position of these interference maxima and minima.
Is Young's double slit formula applicable to all types of waves?
Yes, the formula is applicable to all types of waves, including light waves, sound waves, and water waves. As long as the waves are coherent and exhibit interference, Young's double slit formula can be used to predict the resulting interference pattern.
