HELP Features of A Hyperbola CONIC
  • Thread starter aisha
  • Tags
    Hyperbola
In summary, this is a horizontal hyperbola with center (1,-2), a transversal length of 10, and a conjugate length of 6. The vertices are at (1, -7) and (1, 3), and the foci are located at (1, sqrt(34)-2) and (1, -sqrt(34)-2). The asymptotes are y+2=5/3(x-1) and y+2=-5/3(x-1). To find the intercepts, set x or y equal to zero and solve for the other variable. For this particular hyperbola, there are no x-intercepts, but the y-intercepts can be found by
aisha
584
:cry: [tex] \frac {(x-1)^2} {9} - \frac {(y+2)^2} {25} = 1 [/tex]
I think this is a vertical hyperbola
with center (1,-2) a=5 b=3
Transversal length=10
Conjugate length =6
Vertex (1,-7) and (1,3)
Foci (1,sqrt(34)-2) and (1,-sqrt(34)-2)
Asymptotes y+2=5/3(x-1) and y+2=-5/3 (x-1)
I don't know if all these values are correct I need to find the intercepts if there are any can someone show me how?
If you need to find the intercepts set x and y equal to zero and solve for the other point in each case. That's if you want to find the points (0,y) and (x,0)
EDIT: Just to clarify, I meant you need set each variable equal to zero to find the intercepts separately, not at once.
[tex] \frac {(0-1)^2} {9} - \frac {(y+2)^2} {25} = 1 [/tex]
and
[tex] \frac {(x-1)^2} {9} - \frac {(0+2)^2} {25} = 1 [/tex]
When I set y=0 I got x=-7 or x=7
But when I set x=0 and solved for y I didnt get something as simple as x maybe I did something wrong, I think there are no y-intercepts am I correct?
When I solve for y with x=0 I get an imaginary number
Sketch the graph and think analytically about if there will be a x or y intercept. You have all of the information needed to draw the graph.
Are all of my features correct? can someone please check!
The ones I checked looked ok, I didn't look at them all though. Your center, transverse length, and conjugate length are correct. Show me where you think you messed up.
for the yintercept I got
y=+- Sqrt(-200) -2
when I set x=0 and solved for y. Are my x-intercepts correct? Can you check my foci vertices and asymptotes too.
Nitpick: instead of saying "a=5, b=3", you should state to what those variables actually refer.
This particular example is particularly important, because a lot of people (meaning me!) will immediately think of the usual form: [itex](x-h)^2/a^2 - (y-k)^2/b^2 = 1[/itex].
I think I've made a huge mistake all of the features should be for the horizontal hyperbola not vertical hyperbola, right?
indeed, it is a horizontal hyperbola (if by horizontal, you mean opens sideways).
I have changed all my features but still having problems solving for the x-intercepts please help me what do i do with the denominators?
[tex] \frac {(x-1)^2} {9} - 4/25=1 [/tex]
[tex] \frac {(x-1)^2} {9}=21/25 [/tex]
I don't know what to do with the 9 what is the final answer?
Multiply by 9 and you get:
[tex](x-1)^2 = \frac{21}{25}*9[/tex]
[tex]x - 1 = \sqrt {\frac{21}{25}*9}[/tex]
[tex] x = \sqrt {\frac{21}{25}*9} + 1[/tex]
Is this what you were having trouble with?
mulpliply both sides by 9... bu what you actually mean is
[tex]\frac{(x-1)^2}{9} - \frac{4}{25} = 1 \Longrightarrow \frac{(x-1)^2}{9} = \frac{29}{25}[/tex]
so you can then just say
[tex] (x-1)^2 = 9\frac{29}{25} \Longrightarrow x-1 = \pm\frac{3\sqrt{29}}{5} \Longrightarrow x = 1 \pm \frac{3\sqrt{29}}{5}[/tex]
FAQ: HELP Features of A Hyperbola CONIC
1. What are the key features of a hyperbola?
The key features of a hyperbola are its center, vertices, foci, asymptotes, and transverse and conjugate axes. The center is the midpoint of the transverse axis and is used as the origin for the hyperbola's equation. The vertices are the points on the hyperbola that lie on the transverse axis. The foci are the two points inside the hyperbola that help define its shape. The asymptotes are the lines that the hyperbola approaches but never touches. The transverse and conjugate axes are the two axes that pass through the center of the hyperbola and intersect at the vertices.
2. How do you graph a hyperbola?
To graph a hyperbola, you will need to know its center, vertices, foci, and asymptotes. Start by plotting the center point on a coordinate plane. Then plot the vertices on the transverse axis, making sure they are equidistant from the center. Next, plot the foci on the same axis, making sure they are equidistant from the center and each vertex. Finally, draw the asymptotes through the center, intersecting at the vertices. You can then sketch the rest of the hyperbola's curve by using the asymptotes as a guide.
3. What is the difference between a horizontal and a vertical hyperbola?
The main difference between a horizontal and a vertical hyperbola is the orientation of its transverse and conjugate axes. In a horizontal hyperbola, the transverse axis is parallel to the x-axis and the conjugate axis is parallel to the y-axis. In a vertical hyperbola, the transverse axis is parallel to the y-axis and the conjugate axis is parallel to the x-axis. This difference in orientation affects the equation and graph of the hyperbola.
4. How do you find the equation of a hyperbola given its key features?
To find the equation of a hyperbola, you will need to know its center, vertices, and foci. If the hyperbola is horizontal, the equation is in the form (x - h)^2 / a^2 - (y - k)^2 / b^2 = 1, where (h, k) is the center, a is the distance from the center to the vertices, and b is the distance from the center to the foci. If the hyperbola is vertical, the equation is in the form (y - k)^2 / a^2 - (x - h)^2 / b^2 = 1, where (h, k) is the center, a is the distance from the center to the vertices, and b is the distance from the center to the foci.
5. What are some real-life applications of hyperbolas?
Hyperbolas have various real-life applications, such as in astronomy to calculate the orbits of celestial bodies, in architecture to design arches and domes, and in engineering to design antennas and reflectors. They are also used in navigation systems and in economics to model the relationship between supply and demand. Additionally, hyperbolas can be seen in the shape of a water fountain, the path of a comet, and the curves of suspension bridges.
