Help finding Centripital force angles
In summary, the conversation is about a problem with a merry-go-round and a passenger who is trying to determine the angle his body needs to make with the vertical at different points on the ride. The solution involves calculating the centripetal and tangential forces acting on the passenger and using vector addition to determine the resulting angle.
burban864
:confused: I'm stumped on my hw...can anyone help?
The question is long, but as follows: a merry-go-round has circular platform that is 1m from the central axis at its inner edge and is 5m from the central axis at its outer edge. The ride takes 10s for 1 rotation. A passenger holds himself to the surface with a pair of very stickey shoes and is most comfortable when he orients his body length along the line of the net force on him. Determine the angle his body makes to the vertical A) 1m from the axis, B) 3m from the axis, and c) 5m from the axis. :confused:
Any ideas...just looking to understand how to set this one up equationwise.
Thanks
well, there are two forces action on the passanger, assuming no air resistance. There is a centripital force and a tagential force.
[tex] F_{centripital} = \frac {mv^2}{r} [/tex]
[tex] F_{tangential} = mgsin \theta [/tex]
the tangential force is due to gravity and the centripital one is due to the circular motion. To solve your problem you have to draw some free body diagrams and use vector addition to get the result. Split up your vectors into component form and get your resultant that way. The person will be facing in the angle of this vector. If you need more help, pm me.
Regards,
Nenad
Hi there,
I can definitely help you with this problem. First, let's start by understanding what centripetal force is. Centripetal force is the force that keeps an object moving in a circular path. In this case, the passenger on the merry-go-round is experiencing centripetal force as they rotate around the central axis.
To find the angle that the passenger's body makes with the vertical at different distances from the axis, we can use the equation Fc = mv^2/r, where Fc is the centripetal force, m is the mass of the passenger, v is the velocity, and r is the distance from the central axis.
We know that the ride takes 10 seconds for 1 rotation, so the velocity can be calculated by dividing the circumference of the circular platform (2πr) by the time (10 seconds). This gives us a velocity of 2πr/10 = 0.2πr m/s.
Now, we can plug in the given distances (1m, 3m, and 5m) into the equation and solve for the angle. I'll show you how to do it for the first distance (1m) and you can follow the same steps for the other distances.
Fc = mv^2/r
Fc = m(0.2πr)^2/1
Fc = m(0.04π^2r^2)
Fc = 0.04π^2mr^2
We also know that the net force on the passenger is equal to the centripetal force, so we can set the net force equal to the centripetal force and solve for the angle.
Net force = mg*cosθ
0.04π^2mr^2 = mg*cosθ
We can rearrange this equation to solve for the angle:
cosθ = 0.04π^2mr^2/mg
θ = cos^-1(0.04π^2mr^2/mg)
Now, we can plug in the values for mass (let's say the passenger weighs 50kg), gravity (9.8 m/s^2), and the given distance (1m) to solve for the angle:
θ = cos^-1(0.04π^2*50*1^2/(50*9.8))
θ = cos^-1(0.0128)
θ = 84.3 degrees
So
FAQ: Help finding Centripital force angles
What is centripetal force?
Centripetal force is the force that acts towards the center of a circular path and keeps an object moving in a circular motion.
How do you calculate the centripetal force?
The centripetal force can be calculated using the formula F = mv²/r, where F is the centripetal force, m is the mass of the object, v is the velocity, and r is the radius of the circular path.
How do you find the angles of centripetal force?
The angles of centripetal force can be found by using the formula θ = tan⁻¹(v²/rg), where θ is the angle, v is the velocity, r is the radius, and g is the acceleration due to gravity. This formula gives the angle between the horizontal and the direction of the centripetal force.
What is the role of centripetal force in circular motion?
Centripetal force is responsible for keeping an object moving in a circular path. It acts as a center-seeking force that constantly pulls the object towards the center of the circle, preventing it from flying off in a straight line.
How does the angle of centripetal force affect circular motion?
The angle of centripetal force affects the direction of the object's motion in a circular path. A change in the angle can result in a change in the direction of the object's velocity, causing it to move in a different circular path.
