Help finding distance using work and velocity
In summary, the ski jump should be placed so that a skier with a mass of 85kg will not exceed 30.0m/s. The total work of frictional forces is 38080J and subtracting 4000J leaves 34080J as the energy the skier gains when descending the ski jump.
Salacious Crumb
I'm looking to the distance (h) a ski jump should be placed from the top of the hill so that a skier with a mass of 85kg will not exceed 30.0m/s. I am given an initial velocity of 2.0m/s and the total work of frictional forces to 4000J
How can I use total work to determine distance with the variables I'm given? I'm not looking for the answer I just need to be pointed in the right direction here.
I used the work-energy theorem W(total) = Kinetic (final) - Kinetic(initial)
Kf = 1/2mv^2 = 1/2 * 85kg * (30.0m/s)^2 = 38250J
Ki = 1/2mv^2 = 1/2 * 85kg * (2m/s)^2 = 170J
Wtotal = 38250 - 170 = 38080J
subtract the frictional energy of 4000J
34080J and this is where I'm stuck. Honestly I don't even know if I'm on the right track.
Hi SC, Welcome to Physics Forums.
A question is not a relevant equation. Questions should go in the problem statement. You should list equations you believe may be relevant to the type of problem being solved in the relevant equations section.
Before tackling the details of a problem like this it's a good idea to list all the places where energy is coming from or going. You've recognized the initial KE, final KE, and the frictional force losses. What other form of energy is in play here? When a skier descends a mountain, why does he gain speed?
Sorry, I guess I skimmed over that too quickly. I read it as questions.
The skier accelerates due to the vector of the gravitational force working along the slope of the hill.
So the potential energy (U) of the skier is transformed to K as he moves down the slope.
Kf - Ki = Uf - Ui + Efric -> Kf - Ki = mg(Yf - Yi) + Efric Yf-Yi is h
Am I on the right track now?
Yes, that's the idea. As the skier descends he trades gravitational PE for KE, but also loses KE to friction.
Make sure that you get your signs right to reflect gains or losses. For example, if the skier starts at the top of the hill at height Yi and ends lower down at height Yf, then mg(Yf - Yi) is going to be negative. While it's true that he's losing gravitational PE, his KE should be increased by this amount. Just spend a bit of time making sure that the signs you give the terms reflect what's taking place.
Thank you for your help, I think I have it.
Great! Glad to help.
Related to Help finding distance using work and velocity
1. How is distance calculated using work and velocity?
Distance can be calculated by multiplying the force applied (work) by the distance traveled (velocity). The formula for this is distance = work/velocity.
2. What is the relationship between work, velocity, and distance?
The relationship between work, velocity, and distance can be described using the formula work = force x distance = mass x acceleration x distance. This shows that work and velocity are both factors in determining the distance traveled.
3. Can work and velocity be used to find distance in any situation?
No, work and velocity can only be used to find distance in situations where the force applied and the distance traveled are known. Other factors, such as friction and air resistance, can also affect the distance traveled and may need to be taken into consideration.
4. How does the direction of the force affect the distance calculated using work and velocity?
The direction of the force does not affect the distance calculated using work and velocity. The distance is simply the product of the force and the distance traveled, regardless of the direction in which the force is applied.
5. Can the formula for calculating distance using work and velocity be applied to non-uniform motion?
Yes, the formula for calculating distance using work and velocity can be applied to non-uniform motion, as long as the force applied and the distance traveled are known. However, the resulting distance may not be entirely accurate due to other factors that may affect the motion.
