wmsnyder
- 4
How many kg of mercury to fill a 250ml container?
To find the mass of mercury in a sample, you will need to measure the volume of the sample using a graduated cylinder. Then, you can use the density of mercury (13.534 g/cm³) to calculate the mass by multiplying the volume (in cm³) by the density.
The density of mercury is 13.534 g/cm³. This means that one cubic centimeter (cm³) of mercury has a mass of 13.534 grams (g).
To convert the mass of mercury from kilograms (kg) to other units, you can use the following conversions:
Yes, there is a difference between the mass and weight of mercury. Mass refers to the amount of matter in an object, while weight is a measure of the force of gravity acting on an object. The mass of mercury will remain the same regardless of its location, but its weight will vary depending on the strength of gravity.
Yes, it is important to take safety precautions when handling mercury as it is toxic to humans and the environment. Always wear gloves and protective eyewear when handling mercury. It is also important to properly dispose of any mercury waste to prevent contamination.
