Help finding slope on position-time graph
In summary, to create a velocity-time graph from a position-time graph, you would draw a straight line starting at the initial velocity and ending at 0 after the given time interval. To convert the V-T graph to an A-T graph, a straight line at 0 would represent an acceleration of 0.
ultra_mc
Im trying to make fill in a velocity-time graph from the a picture of a position-time graph. The position-time graph starts at 20m (no direction indicated) and slides dowb to 5m in 4 seconds. The slope would be -4m/s right? But the V-T graph I have to fill in has a maximum velocity of 6 m/s and a min of -6 m/s. What is the corect way of finding this?
PS. while typing this I might have found out. Would you just draw a straight line starting at 4m/s until 4 seconds?
Edit: Then I would have to convert the V-T graph to an A-T graph, using the slope of the V-T graph (which I think would be 0) how would that be drawn on the A-T graph?
^^^That would be a straight line at 0 right?
Yes, your solution is correct. The V-T graph would consist of a straight line starting at 4 m/s and going to 0 m/s after 4 seconds. To convert the V-T graph to an A-T graph, you would draw a straight line at 0, as you mentioned. This would indicate that the acceleration is 0.
Dear student,
Thank you for reaching out for help with finding the slope on a position-time graph. It seems like you have a good understanding of the concept, but let me clarify a few things for you.
Firstly, you are correct in saying that the slope of the position-time graph would be -4m/s. This is because the slope represents the rate of change of position over time, and in this case, the position is changing by 15m (20m to 5m) in a time of 4 seconds. So the slope would be -15m/4s which simplifies to -4m/s.
Now, when it comes to filling in the velocity-time graph, you are correct that you would start at a velocity of 4m/s (since the slope is -4m/s) and draw a straight line until 4 seconds. However, to make the graph more accurate, you would need to consider the fact that the velocity is changing at a constant rate. This means that the velocity would decrease by 1m/s every second, resulting in a final velocity of 0m/s at 4 seconds. So the graph would look like a straight line decreasing from 4m/s to 0m/s.
Now, to answer your question about converting the velocity-time graph to an acceleration-time graph, you are correct in saying that the slope of the velocity-time graph would be 0m/s^2. This is because the velocity is not changing over time, so the rate of change (i.e. the slope) would be 0. Therefore, the acceleration-time graph would be a straight line at 0m/s^2.
I hope this helps clarify the process for you. Remember, when working with graphs and finding slopes, it is important to always pay attention to the units and the direction of the graph. Keep up the good work!
FAQ: Help finding slope on position-time graph
What is a position-time graph?
A position-time graph is a visual representation of an object's position over a period of time. It shows the relationship between an object's position and time, with time usually being on the horizontal axis and position on the vertical axis.
How do you find the slope on a position-time graph?
To find the slope on a position-time graph, you need to choose two points on the graph and calculate the change in position (vertical change) over the change in time (horizontal change). This is also known as rise over run.
What does the slope represent on a position-time graph?
The slope on a position-time graph represents the velocity of the object. A steeper slope indicates a higher velocity, while a flatter slope indicates a lower velocity. The slope can also be negative, indicating that the object is moving in the opposite direction.
How does the slope on a position-time graph change for an object at rest or in motion?
If an object is at rest, the slope on a position-time graph will be 0, as there is no change in position over time. If an object is in motion, the slope will be non-zero, with the value depending on the velocity of the object.
Can you calculate the acceleration of an object using a position-time graph?
Yes, the acceleration of an object can be calculated using a position-time graph by finding the change in velocity (vertical change) over the change in time (horizontal change). This is also known as the average acceleration.
