Help finding the vibrational frequencies and normal modes
In summary: That's more work than I want to do!You first need to find the equilibrium positions, which you can do by solving for ##x_{1\text{eq}}## and ##x_{2\text{eq}}##. Then, you can use the derivatives to find the equilibrium expressions.
1v1Dota2RightMeow
76
Let's say that I have a potential ##U(x) = \beta (x^2-\alpha ^2)^2## with minima at ##x=\pm \alpha##. I need to find the normal modes and vibrational frequencies. How do I do this?
##F=-kx=-m\omega ^2 x##
##\omega = \sqrt{\frac{k}{m}}##
##U(x)=\frac{1}{2}m\omega ^2 x^2##
The Lagrangian for this system is given by:
##L=(1/2)m(\dot{x}_1^2 + \dot{x}_2^2)-4\alpha^2 \beta (x_1 + \alpha)^2 -4\alpha^2 \beta (x_2 + \alpha)^2 - (1/2) k (x_2 - x_1 -2\alpha)^2 ##
I found an example that uses matrices. The general idea seems to be to put the Lagrangian into matrix form, set up the characteristic equation, and then solve for eigenvalues and eigenvectors. But how do I put this Lagrangian into matrix form?? Note - I have Mathematica at my disposal.
It isn't writing the Lagrangian in matrix form. Rather, one would apply the Euler-Lagrange equations to the Lagrangian to get the equations of motion. This will result in, in essence*, an equation that looks like
$$\frac{d^2\mathbf{x}}{dt^2} = -K \mathbf{x}$$
where ##\mathbf{x}## is a column vector with your two generalized coordinates (##x_1## and ##x_2## in your case) and ##K## is a 2x2 matrix. The trick then is to find a pair of coordinates such that the equations of motion are decoupled. Do you know how to do that? Think of what you can do to the matrix ##K##, that you may have covered in a linear algebra course.
*There could be constant terms here, but they can be dealt with by translating the coordinates appropriately.
Edit: I noticed your potential isn't quadratic, but that's OK; the trick is to work out what the system looks like for small enough oscillations.
Yup, in the Lagrangian I reduced using Taylor series.
Excellent, then you're all set. Reduce the system to that format (which if you notice, is analogous to that of a harmonic oscillator but with variables that are vectors) and see what else you can do.
Ok so I found the coupled equations to be
##\ddot{x_1} =(\frac{-8\alpha^2 \beta -k}{m})x_1 + (\frac{-8\alpha^3 \beta + kx_2 -2k \alpha}{m}) ##
##\ddot{x_2} =(\frac{-8\alpha^2 \beta -k}{m})x_2 +( \frac{8\alpha^3 \beta + kx_1 +2k \alpha}{m}) ##
Excellent, now get it in the form
$$\begin{pmatrix}
\displaystyle\frac{d^2x_1}{dt^2} \\
\displaystyle\frac{d^2x_2}{dt^2}
\end{pmatrix} = -K
\begin{pmatrix}
x_1 \\
x_2
\end{pmatrix} + \text{whatever}
where ##K## is a 2x2 matrix. Mind you, I am not checking your algebra!
$$\begin{pmatrix}
\end{pmatrix} = -K
\begin{pmatrix}
x_1 \\
x_2
Ok so then ##K=\begin{bmatrix}\frac{8\alpha^2\beta + k}{m} & -k/m\\-k/m & \frac{8\alpha^2\beta + k}{m}\end{bmatrix}##. I removed a negative sign from inside the matrix because it looks like you pulled it out to be in front of the ##K##.
But now I have absolutely no clue about how to decouple these equations. Linear algebra wasn't my best math course... hehe...
Can I just completely throw out those constants that you've labeled "whatever"??
I was reviewing a bit (I also have my graduate qualifier in a bit :oldeek:), and it seems there may be a less "systematic" way to solve these kinds of problems. Here's how it goes. First, the "whatever" terms need to go away; this can be done by setting ##\ddot{x}_1 = \ddot{x}_2 = 0## and seeing for what ##x_1## and ##x_2## there is equilibrium; we call these positions ##x_{1\text{eq}}## and ##x_{2\text{eq}}## respectively. You then define a new pair of variables ##x_1' = x_1 - x_{1\text{eq}}## and ##x_2' = x_2 - x_{2\text{eq}}##, and if you plug these new variables into your differential equations, you should get rid of any constant terms.
And this is where the actual process begins; let us assume a solution of the form ##x_1'(t) = A_1 \exp{(i \omega t)}## and ##x_2'(t) = A_2 \exp{(i \omega t)}##. If you plug this into your differential equations and cancel out the complex exponential, you end up with an expression that looks like
$$B \begin{pmatrix}
A_1 \\
A_2
\end{pmatrix} =
\begin{pmatrix}
0 \\
\end{pmatrix}
where ##B## is a 2x2 matrix, where you'll have somewhere in it the ##\omega## that we introduced before in our ansatz. Now here is the most important thing about these problems: we are interested in finding nontrivial solutions to this system of equations in ##A_1## and ##A_2##. Thus we are interested in seeing when the inverse of the matrix ##B## does not exist. This will happen when its determinant vanishes, and this is what we need to do to find the eigenfrequencies. From here on it's mostly an algebra problem. Do you know how to continue, and then later find the normal modes?
Going in order of what you've written, this is my first question: are the equilibirum points the points where the potential of the wells is at a minimum? I found those to be at ##x=\pm \alpha##. But then again this does not include the spring potential...
Oh gosh oh gosh - I just realized that I forgot to explicitly mention that there is a spring connecting the two particles. The scenario is that there is a double well potential with one particle in each well. The particles are connected to each other by a spring. We are considering small oscillations about the minima.
Related to Help finding the vibrational frequencies and normal modes
1. What is the significance of finding the vibrational frequencies and normal modes?
Finding the vibrational frequencies and normal modes allows us to understand the behavior of molecules and materials at a microscopic level. This information can be used to predict how a molecule will react to different stimuli, and can also help in designing new materials with specific properties.
2. How do scientists find the vibrational frequencies and normal modes?
Scientists use various techniques such as infrared spectroscopy, Raman spectroscopy, and nuclear magnetic resonance (NMR) spectroscopy to analyze the vibrations of molecules. These techniques involve measuring the absorption or scattering of light by molecules, which provides information about their vibrational frequencies and normal modes.
3. Can the vibrational frequencies and normal modes be calculated theoretically?
Yes, theoretical calculations using quantum mechanics can also provide information about the vibrational frequencies and normal modes of molecules. However, these calculations can be complex and may require high-performance computing.
4. What factors can affect the vibrational frequencies and normal modes?
The vibrational frequencies and normal modes of molecules can be affected by several factors, including the mass of the atoms, bond strength, and molecular geometry. Changes in temperature and pressure can also alter the vibrational frequencies and normal modes.
5. How is the information about vibrational frequencies and normal modes used in practical applications?
The information about vibrational frequencies and normal modes is used in a variety of practical applications, such as drug design, material synthesis, and environmental monitoring. It can also help in identifying unknown substances, studying protein structures, and understanding the dynamics of chemical reactions.
