Help for supercell, Bloch function
  • Thread starter jhzhou2010
  • Tags
    Function
In summary, there is a relation between the periodic part of Bloch function in a primitive cell and that in a supercell. The vector k in the normal lattice becomes k'+K in the supercell lattice, where K can take on 3 values. This results in a new Bloch function u'_{nKk}(x) that is related to the original Bloch function u_{nk}(x) by a phase factor exp(iKx). The length of the supercell is 3 times longer than the normal cell, and K can take on values of 0, 2pi/3d, and 4pi/3d.
jhzhou2010
I recently have a puzlle that what is the relation between the periodic part of Bloch function in primitive cell u_nk(r) and that in supercell, e.g., three primitive cells in one of the directions. Are they the same one?
pls give me some hints or explanations!
thanks~~
Well, the unit cell in the reciprocal lattice is smaller in the case of supercells than in the case of normal cells in direct lattice. That is the vector k for the normal lattice will become k'+K in case of the supercell lattice where K may take on 3 values in the case of a supercell which is 3 times longer than a normal cell.
Hence
[tex]u_{nk}(x)\exp(ikx)=u'_{NKk}\exp(ik'x)[/tex]
or
[tex]u'_{nKk}(x)=u_{nk}(x)\exp(iKx)[/tex]
If the length of the original unit cell is d and the length of the supercell is 3d (at least for a space group with orthogonal axes)
then [tex]K \in \{0,2\pi/3d,4\pi/3d\}[/tex].
Thanks very much for your useful reply!
Related to Help for supercell, Bloch function
1. What is a supercell in the context of materials science?
A supercell is a unit cell in a crystal structure that contains multiple copies of the original unit cell. It is used to simulate larger and more complex crystal structures in materials science research.
2. What is a Bloch function and how does it relate to supercells?
A Bloch function is a mathematical function that describes the wave-like behavior of electrons in a crystal lattice. It is important in supercell calculations because it allows for the simulation of the electronic properties of a larger crystal structure by using the periodicity of the unit cell.
3. How can supercells be used to study defects in materials?
Supercell calculations can be used to simulate the presence of defects, such as vacancies or impurities, in a crystal structure. By comparing the electronic properties of the perfect crystal to that of the defective crystal, researchers can gain insights into the effects of these defects on material behavior.
4. What is the role of symmetry in supercell calculations?
Symmetry is crucial in supercell calculations as it allows for the efficient description of the crystal structure. By taking advantage of the symmetry of the crystal, the size of the supercell can be reduced, making the calculations more feasible.
5. How can supercell calculations help in the design of new materials?
Supercell calculations can provide valuable insights into the electronic and structural properties of materials, which can aid in the design of new materials with specific properties. By simulating different crystal structures and defects, researchers can predict how a material will behave and make informed decisions in the design process.
