HELP I solving a set problem
  • Thread starter jmwilson11268
  • Tags
    Set
In summary, the conversation is about a student seeking help with a set problem and a moderator providing guidance on how to approach it by suggesting to draw Venn Diagrams.
jmwilson11268
HELP! I need help solving a set problem
12) For each of the following pairs of sets, explain which is a subset of the other. If neither is a subset of the other, explain why.
a) A-B and A-(B-C)
b) AUB and (AUB)-Ø
a) A-B and A-(B-C)
b) AUB and (AUB)-Ø
Hello jmwilson11268. Welcome to PF !
What have you tried?
Where are you stuck?
According to the rules for the Homework Help section of this Forum:
... NOTE: You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums.
I don't know how to start this problem. I just need a little push in the right direction.
Draw a Venn Diagram for each.
Okay. Thanks!
FAQ: HELP I solving a set problem
How do I approach solving a set problem?
When approaching a set problem, it is important to first understand the question and identify what information is given. Then, try to break down the problem into smaller, more manageable parts. Use logical reasoning and problem-solving skills to determine the steps needed to solve the problem.
What strategies can I use to solve a set problem?
There are several strategies that can be used to solve a set problem. Some common techniques include working backwards, making a list or table, using visualization, and trying different methods to see what works best.
How can I check if my solution to a set problem is correct?
To check if your solution to a set problem is correct, you can go back and retrace your steps to see if you followed the correct logic. You can also plug your solution into the original equation or problem to see if it works. Additionally, you can ask someone else to check your solution or use online resources for verification.
What should I do if I get stuck on a set problem?
If you get stuck on a set problem, take a step back and take a break. Sometimes, giving your mind a break can help you approach the problem with a fresh perspective. You can also try looking for similar problems or seeking help from a teacher or tutor.
How can I improve my skills in solving set problems?
The best way to improve your skills in solving set problems is through practice. The more problems you solve, the more you will become familiar with different techniques and strategies. You can also read books or watch videos on problem-solving methods and try to apply them to different types of set problems.
