Help in showing that this inner product is zero
The discussion revolves around demonstrating that the inner product of two plane wave solutions, ##(u_{\vec{k}},u^{*}_{\vec{k}'})##, equals zero. Participants note that the calculation leads to an integral of the form $$\int \exp [i(\vec{k}+\vec{k}')\cdot\vec{x}]\mathrm{d}^3 x$$, which raises questions about the appropriate Hilbert space context, specifically whether it is ##\mathrm{L}^2(\mathbb{R}^3)## or a finite region ##D##. The expectation is that the result should yield a Dirac-delta function, indicating orthogonality when ##\vec{k} \neq \vec{k}'##. Clarification on the setup of the problem is necessary for accurate resolution. The conversation emphasizes the importance of defining the space in which the inner product is calculated.
user1139
I want to show that the inner product between the plane wave solution and its conjugate is zero.
The inner product is defined as ##(u_{\vec{k}},u_{\vec{k}'})=-i\int u_{\vec{k}}\partial_{t}u^{*}_{\vec{k}'}-u^{*}_{\vec{k}'}\partial_{t} u_{\vec{k}}\,\mathrm{d}^3 x##
The unormalised plane wave solution is given as ##u_{\vec{k}}=e^{i\vec{k}\cdot\vec{x}-i\omega t}##. I want to show that ##(u_{\vec{k}},u^{*}_{\vec{k}'})=0##. However, I don't seem to be able to get the answer through direct calculation. Any hints on how to obtain the answer?
Show your work please.
Your question is also not well posed. Which Hilbert space are we supposed to work in? Is it ##\mathrm{L}^2(\mathbb{R}^3)## or is it ##\mathrm{L}^2(D)## with some finite region ##D##?
It seems that the inner product is propotional to $$\int \exp [i(\vec{k}+\vec{k}')\cdot\vec{x}]\mathrm{d}^3 x.$$
Shouldn't it be a Dirac-delta function?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
