Help In understanding Rate Of Change in mm per sec
In summary: = (25 mm x 136.794) / 216 sec= (25 mm x 136.794) / (3.6 x 60 x 1) sec= (25 mm x 136.794) / (3.6 x 60 x (1000/1000)) sec= (25 mm x 136.794) / (3.6 x 60 x (1000/1000)) sec= (25 mm x 136.794) / (3.6 x 60 x 1000) sec= (25 mm x 136.794) / 360000 sec= (25 mm) x (136.794/360000
tomtomtom1
160
Hi everyone
Firstly this is not a homework question, i work in transport engineering. ( i do study part time which is why i sometimes post in the homework section)
Now to the problem.
I am trying to understand how to solve this problem, i already know the answer.
A train is traveling on straight & level track at 136.794kph.
It approaches a transition. The transition is 60m long.
Along the transition the Left Rail rises linearly over the length of the transition relative to the right Rail by 25mm.
Calculate the rate of change the left rail raises over the right in mm per sec over the 60m transition at 136.794kph.
i know that the answer is (25mm * 136.794kph) / (3.6 * 60m)
what i need help with is where does the 3.6 some from? and why do you times 25mm by 136.794kph?
can anyone explain
Thanks
The transition length is 60 m long. In this distance, the rails rise by 25 mm. Doesn't this suggest a slope?
The train is traveling at 136.794 km/hr. How do you convert 136.794 km/hr to a speed measured in m/s?
Yes there is a slope and the slope is 25mm/60m = 1m per 0.416mm which means for every 1m the train travels along the transition the left rail rises by 0.416mm.
1kph = 0.277777778 m/s so 136.794km/hr in m/s is 136.794*0.277777778 = 37.998m/s.
rate of change the left rail raises = 25mm / (time needed to cross 60m)
= 25 mm / (60 m / velocity)
= 25 mm / (60 m / 136.794 km per hour)
Now, 1 km per hour = 1000 m / 3600 sec = 1/3.6 meter per sec
So,
rate of raise = 25 mm / (60 m / ((136.794 / 3.6) meter per sec))
= 25 mm / (3.6 x 60 / 136.794) sec
= (25 mm x 136.794) / (3.6 x 60) sec
Sure, I'd be happy to help you understand the rate of change in millimeters per second in this scenario. First, let's define what rate of change means. Rate of change is a measure of how quickly a quantity is changing over time. In this case, we are interested in the rate at which the left rail is rising relative to the right rail.
To calculate the rate of change, we need to determine the change in the left rail's height over a given time interval. We know that the left rail rises by 25mm over a distance of 60m. However, the question asks for the rate of change in millimeters per second, so we need to convert the distance to seconds.
To do this, we use the formula speed = distance/time. In this case, the speed is given as 136.794kph (kilometers per hour). We need to convert this to meters per second, which is a more commonly used unit for speed in scientific calculations. To do this, we divide 136.794 by 3.6 (since there are 3,600 seconds in an hour) to get the speed in meters per second, which is approximately 37.998 meters per second.
Now, we can use the formula for rate of change, which is change in quantity/change in time. In this case, the change in quantity is 25mm and the change in time is the distance in meters divided by the speed in meters per second. This gives us (25mm * 37.998m/s) / 60m = 25mm * 0.6333s/m = 15.83mm/s.
So, the rate of change in millimeters per second is 15.83mm/s. The 3.6 in the original formula comes from the conversion factor between kilometers per hour and meters per second. And we multiply 25mm by the speed in meters per second to convert the distance from meters to millimeters.
I hope this helps clarify the calculations for you. Let me know if you have any further questions.
FAQ: Help In understanding Rate Of Change in mm per sec
What is the definition of rate of change in mm per sec?
The rate of change in mm per sec refers to the measurement of how quickly a quantity is changing over a specific period of time, specifically in terms of millimeters per second. It is a measure of the slope or steepness of a line on a graph.
Why is understanding rate of change important in scientific research?
Understanding rate of change is important in scientific research because it allows scientists to analyze and compare data, make predictions, and identify trends. It also helps in determining the relationships between different variables and can provide valuable insights into various physical processes.
How is rate of change calculated?
The rate of change is calculated by dividing the change in the quantity of interest by the time interval over which the change occurred. This is represented by the formula: rate of change = (final value - initial value) / time interval.
What are some real-world examples of rate of change in mm per sec?
Some real-world examples of rate of change in mm per sec include measuring the speed of an object in motion, calculating the growth rate of a plant or animal, and analyzing the flow rate of a liquid or gas. It can also be used to study changes in weather patterns or the movement of tectonic plates.
How can rate of change be graphically represented?
Rate of change can be graphically represented by plotting the data points on a graph and drawing a line connecting them. The slope of the line represents the rate of change, with a steeper slope indicating a higher rate of change and a flatter slope indicating a lower rate of change. This visual representation makes it easier to understand and analyze the data.
