jendrix
- 122
- 4
Hello,
I have been looking to build a pmu similar to this device, it will be for domestic use.
https://www.digikey.com/en/articles/techzone/2014/jan/low-cost-microcontroller-based-phasor-measurement-units-improve-smart-grid-reliability
I am having a bit of trouble with the sampling part and was unsure whether it was a typo. It says "AC signals are measured 30 times per cycle and 1200 times per second"
If this is from a 60Hz supply then wouldn't it end up 1800 times per second?
There is also this part later on
"The microcontroller receives a filtered analog signal as input to the A/D. These signals are converted at a minimum sample rate of 1200 ksps"
Wouldn't 1200ksps be too high, surely that would be a sampling rate of 1.2MHz, I have seen other devices which sample in the KHz range.Regards
