Help Me Comprehend This.... (change of units)
  • Thread starter ProjectTruth
  • Tags
    Units
In summary, the conversation discusses converting a quantity from cubic feet to cubic inches. The formula used is 3 x 12 x 12 x 12, resulting in the answer of 5,184 cubic inches. However, one participant suggests using the conversion factor of 12 inches per foot to simplify the calculation. Another participant provides a visual explanation of how the conversion works.
ProjectTruth
Hello,
First off, I apologize if this is in the wrong section. I didn't think this would constitute as a homework problem,as I'm not really asking to solve a problem,but more, I'm asking you all to help me comprehend and mentally vizualize this.
So I had a story problem that went along the lines of this:
"I Have 3ft^3 of stuffing for a project,but the project requires that the quantity be in cubic inches. How many In^3 do i have?"
Now,ultimately, the answer was 5,184"
Using the formula-3×12×12×12
Is it just me,or does this seem wrong?
I feel that the answer would be 36 cu.in. in the sense that the quantity is the same,only stated in inches rather than feet.
Can anyone help me comprehend this somehow? Am I just not thinking 3 dimensionally? Or am I in the right here?
Appreciate it in advance.
-ProjectTruth
Mathematics news on Phys.org
If you have 1 cubic feet, how many cubic inches do you have?
If you have 2 cubic feet, how many cubic inches do you have?
If you have 3 cubic feet, how many cubic inches do you have?
If you have 4 cubic feet, how many cubic inches do you have?
ProjectTruth said:
Hello,
"I Have 3ft^3 of stuffing for a project,but the project requires that the absolute quantity be in cubic inches. How many In^3 do i have?"
-ProjectTruth
The easiest way to do dimensional changes is by multiplying by "1", so that the quantity changes correctly along with the units.
1 foot = 12 inches, so do this:
[tex]3 ft^3 * (12in/ft)^3 = 3 * 1728 ft^2 in^3 / ft^3 = 5184 in^3[/tex]
To help with visualisation:
Imagine a cubic inch as a physical cube with 1 inch sides.
You need 12 such cubes to make a line of 1 foot length and 1 inch both in height and width.
You need to stack 12 such lines one on top of another to get a wall of 1 foot length and height, but still one inch in width.
You need 12 such walls one next to another to make a cube 1 foot by 1 foot by 1 foot.
You need 3 such cubes to get 3 cubic feet.
Likes Mentallic
This was very helpful actually,and was exactly what I was looking for.
Thanks to all other participants.
Cheers.
FAQ: Help Me Comprehend This.... (change of units)
How do I convert units from one system to another?
To convert units from one system to another, you can use conversion factors. These factors represent the relationship between the two units and can be found in conversion tables or calculated using conversion formulas.
What are the most commonly used conversion factors?
The most commonly used conversion factors are those for length, mass, time, temperature, and volume. For example, 1 meter is equal to 3.28 feet, 1 kilogram is equal to 2.2 pounds, and 1 liter is equal to 0.26 gallons.
How do I determine which conversion factor to use?
To determine which conversion factor to use, you need to know the starting unit, the desired unit, and the relationship between the two units. You can then select the conversion factor that contains both the starting and desired units.
Can I convert units using a calculator?
Yes, you can convert units using a calculator. Many scientific calculators have built-in unit conversion functions that allow you to easily convert between different units.
Do units of measurement change in different countries?
Yes, units of measurement can vary between different countries. For example, the United States uses the imperial system while many other countries use the metric system. It is important to be aware of these differences when working with international data or collaborating with colleagues from different countries.
