Help me find the arc length of a parametric equation....
In summary, when solving an integral involving the absolute value of a function, it is important to use the correct notation and account for the range of the function in order to avoid errors in the final answer.
Rijad Hadzic
321
1. The problem statement, all variables and given/k
nown data
[itex] x = (sin(t))^2 [/itex] [itex] y = (cos(t))^2 [/itex] t goes from 0 to 3 pi
∫[itex] \sqrt{ {(dx/dt)}^2 + {(dy/dt)}^2 } dt[/itex]
∫[itex] \sqrt{ {(2sin(t)cost)}^2 + {(-2cos(t)sin(t))}^2 } dt[/itex]
∫[itex] \sqrt{ 4(sin(t)cos(t))^2 + {(-2cos(t)sin(t))}^2 } dt[/itex]
∫[itex] \sqrt{ 4(sin(t)cos(t))^2 + 4(cos(t)sin(t))^2 } dt[/itex]
∫[itex] \sqrt{ 8(sin(t)cos(t))^2 } dt[/itex]
[itex]2\sqrt 2 [/itex]∫[itex] \sqrt{ (sin(t)cos(t))^2 } dt[/itex]
[itex]2\sqrt 2 [/itex]∫[itex] { (sin(t)cos(t)) } dt[/itex]
keep in mind my bounds are from 0 to 3 pi right now
so I integrate this using u = sin (t) du = cos(t) dt
and get
(root 2)(sin(t))^2 from 0 to pi/3
now when I evaluate I get 0-0
where did my integration go wrong?
nown data
and get
Never, never just write ##\sqrt{X^2} = X## because half the time it is wrong. What IS always correct is ##\sqrt{X^2} = |X|.##
so it should be absolute value sin(t)cos(t) ??
I thought that was what I said.
So where do I go from here? can I just call that the absolute value of 2sin since sin and cos have the same range?
I have already offered all the help I feel I can according to PF rules.
Thanks for the help.
Related to Help me find the arc length of a parametric equation....
1. What is the definition of arc length?
The arc length of a parametric equation is the distance along the curve from one point to another, measured along the curve itself.
2. How do you find the arc length of a parametric equation?
To find the arc length, you must first determine the parametric equations for x and y in terms of a third variable, typically t. Then, use the following formula:
Arc Length = ∫ab √(dx/dt)2 + (dy/dt)2 dt
where a and b are the starting and ending values of t.
3. Can you provide an example of finding arc length for a parametric equation?
For the parametric equation x = 2t, y = t2, the starting and ending values of t are 0 and 1, respectively. Plugging these values into the formula, we get:
Arc Length = ∫01 √(2)2 + (2t)2 dt
= ∫01 √4 + 4t2 dt
= ∫01 √4 + 4t2 dt
= ∫01 √4 + 4t2 dt
= ∫01 √4 + 4t2 dt
= ∫01 √4 + 4t2 dt
= ∫01 2 + 4t2 dt
= 2t + 4t3/3 + C
Evaluating at the limits of integration, we get the final answer of 2 + 4/3 = 6/3 = 2 units.
4. Are there any special cases to consider when finding arc length of a parametric equation?
Yes, there are a few special cases to keep in mind. If the parametric equations are given in terms of polar coordinates, the formula for arc length changes to: Arc Length = ∫ab √(r)2 + (r')2 dt. Additionally, if the parametric equations contain a trigonometric function, you may need to use trigonometric identities to simplify the integral.
5. How is the arc length of a parametric equation used in real-life applications?
The arc length of a parametric equation is a useful tool in many fields of science and engineering, particularly in studying the motion of objects. For example, it can be used to calculate the distance traveled by a particle along a curved path, or the length of a wire in an electrical circuit. It is also used in calculus to find the surface area of 3D objects and to solve optimization problems.
