MHB Help Me Find the Perimeter of Tn+1
  • Thread starter Thread starter veronica1999
    Perimeter
The discussion revolves around calculating the perimeter of a sequence of triangles, starting with T1, which has sides 2011, 2012, and 2013. The sequence is defined such that Tn+1 has side lengths determined by the points of tangency of the incircle of triangle ABC. The perimeter of the final triangle in the sequence is stated to be 1509/28, although there are some calculations leading to different values, including 1509/128. The triangle inequality rule is highlighted as a crucial factor in determining the validity of the triangle's existence in the sequence. Ultimately, the correct perimeter is confirmed to be 1509/128.
veronica1999
Could I get some help please?Let T1 be a triangle with sides 2011, 2012, and 2013. For n > = 1, if Tn = triangle ABC
and D, E, and F are the points of tangency of the incircle of triangle ABC to the
sides AB, BC, and AC, respectively, then Tn+1 is a triangle with side lengths
AD, BE, and CF, if it exists. What is the perimeter of the last triangle in the
sequence (Tn) ?
The answer is 1509/28.
Please do not laugh at my solution.
6036/2 , 6036/4 ,6036/8 ... 6036/4096.
I put 4096 as the last term because the next one is 8192
My answer 6036/4098 = 1509/1024
Mathematics news on Phys.org
sequence (Tn) ?
The answer is 1509/128.
The stopping condition is where the longest of \(AD\), \(BE\), \(CF\) for \(T_n\) is greater than the sum of the other two.
So do you know the relationship between the sides of consecutive triangles in the sequence?CB
Thanks!
I see I forgot to consider the triangle inequality rule.
6036/512 = 11.787
11.787/3 = 3.92
2.92 3.92 4.926036/1024 = 5.89
5.89/3 = 2.96
0.96 1.96 2.96
Oops it was my mistake. I meant 1509/128. Sorry.
Which is what I get.
CB
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
