Help me understand this proof, so I can present it
  • Thread starter semidevil
  • Tags
    Proof
In summary: I don't know what that means actually...can someone simplify that meaning for me...because it seems important, and if I don't know what it means, then I don't know how to explain it to the class. And in (2), all these contributions sum to... the toal flux of intergral of S. again, don't know what that means...)So in order to prove the divergence theorem, we need to show that it holds for each little cube. For each little cube, either the volume is inside the cube, or it's part of the surface of the cube. We can do this by proving that the sum of the volumes of the cubes inside the
semidevil
157
so I googled up a proof of te divergence theorem, and plan to explain it...I want to make sure I am understanding the whole proof before I make a fool of myself.
here is a link to the proof I found. It is section 7.2
http://www.enm.bris.ac.uk/admin/courses/EMa2/Lecture%20Notes%2004-05/vcalc7.pdf
ok, so basically, I"m going to start out and give the formula for divergence, and I will try to prove it.
-so let F = Fi + Fj + Fk, and I"m going to divde this solid into N small cubes, of volume del(V). so the volume of each cube is devl(V)
-so if we can show that it holds for each little cube, then the proof is done.
because: the volume is equal to the sum, and (1)each little cube will be either inside, or (2) each will be part of the surface.
(in the pdf, it states that in (1), the flux integeral is exactly canceled by the flux integeral of the neighboring cub. I don't know what that means actually...can someone simplify that meaning for me...because it seems important, and if I don't know what it means, then I don't know how to explain it to the class. And in (2), all these contributions sum to the toal flux of intergral of S. again, don't know what that means...)
-so I consider a cube. I will label each face S1, 2, 3, 4, 5, S6.
so for S1, ndS = idydz, and double integeral of F * ndA = integeral from (zi-del(z) to zi +del(z) and integeral (yi-del(y) + yi+del(y) of F1(xi + del x, y, z)dydz.
now, first, I don't know what this integeral is saying. what are we computing here? and where is all the liimits coming from? it's been a while for me since calc class, so I really forgot what n and the del's are.
and then, we take S2 and do the same, w/ the corresponding limits, and different function.
so first of all, where are the functions coming from?
anyways, once we get S1 and S2, we add them up, and by FTC, we get triple integeral partial F/partial x, dV.
and we do the same for S3 + S4, and S5 + S6.
and then we add them all up and get the divergence theorem.
so my final question is, when we did the integeration, what did we integerate exactly...and why when we added them all up, did it prove the divergence theorem.
I really wan't to undersand this, so if someone can help..that would be great.
thanx
I'll try to help. We have this object A... we divide it up into a bunch of cubes... The first thing to understand is that the flux through the surface of A, is the sum of the fluxes through all the little cubes.
The proof doesn't exactly make this clear. That picture right under where it says "Proof of the divergence theorem"... where it has one cube on top of the other... Suppose we want the total flux through that 2 cuboid object.
The flux through the bottom surface of the top cube, is canceled by the flux through the top surface of the bottom cube. This happens because the normal vector is in the opposite direction. The force vector is the same and dA is the same.
So the total flux of the 2 cube object is the flux over the surface area (5 sides of the one cube and 5 sides of the other cube).
So when two cubes have a surface in common (they are neighbors)... their fluxes through that side cancel each other out... In a similar manner the fluxes through all the cubes inside the object A cancel each other out... until all that's left is the flux through the surface...
Think of it like this... when adding up the fluxes of all the little cubes, you're adding up the fluxes through the square surfaces of the cubes... for each cubical surface that's within the object, two cubes that have that surface. So those two fluxes cancel. The only cubical surfaces that are left are those that are on the surface (outer part) of the object.
I hope this helps... Let me know, and I'll try to help with the rest.
Hmm... I may sound picky, but no finite union of cubes together will be equal to, say, a sphere. So the 'sum of the cubes' is in general not equal to the interior of a closed surface. (The idea is to take the limit ofcourse).
(1)Consider a side of a small cube. This side belongs to exactly two cubes. So the flux through a side of a cube is the same as the flux through this side when it belongs to the neighbouring cube, but with opposite sign. Hence, they cancel.
(2)Since all the internal sides of the cubes cancel out against each other (a cube that is surrounded by 6 other cubes doesn't add to the total flux, because it all cancels against the flux through the sides belonging to the 6 neighbouring cubes), the only flux that matters is the one going through the cubes at the surface, since they don't have neighbouring cubes all around them.
Haven't read the rest of the proof. Instead, try to prove it in the following way.
Assume the region is of the following type:
[tex]V=\{(x,y,z)|(x,y) \in D, u_1(x,y) \leq z \leq u_2(x,y)\}[/tex]
where D is the projection of V onto the xy-plane.
Then show that:
[tex]\iint_S F_1\vec i \cdot \vec n dS = \iiint_V \frac{\partial F_1}{\partial x}dV[/tex]
[tex]\iint_S F_2\vec j \cdot \vec n dS = \iiint_V \frac{\partial F_2}{\partial y}dV[/tex]
[tex]\iint_S F_3\vec k \cdot \vec n dS = \iiint_V \frac{\partial F_3}{\partial z}dV[/tex]
(Does require calculus dealing with integration over general regions).
Note that the DT is proven for this class of regions if the above is shown.
To complete the proof, show that the theorem holds for a finite union of V type regions.
The proof in the pdf is more insightful intuitively, but the above is a little more rigorous. Try doing both.
ok, thanks guys...I Understand the flux part...now, where it says ndS = idydyz, and it does that double integeral for S1...what does that mean actually?
what is it?
and why did we consider a cuboid w/ length 2del(x), 2del(y), and 2del(z)?
what does 2(del)x mean?
They're getting the flux through the surface S1. An infintesimal area on S1, is dS=dxdy. The unit normal to the surface S1 is the vector i.
Over an infintesimal area on S1, the flux through the surface is F.ndS=F.idS=F.idxdy (I'm using . for dot product... F and i are vectors. I've still to learn latex)
So the total area on S1 is that integral of F.idxdy over the surface S1, which becomes a double integral, as you have to integrate over all the x and all the y, on that surface.
In the proof they seem to sometimes use dS, and sometimes dA but they're the same thing.
semidevil said:
what is it?
It's just arbitrary... the idea is to eventually let the dimensions of the cube approach 0(in the limit). They could have made the dimensions, del(x), 5(del)y, 8(del)z... it doesn't matter. Only advantage is to make the math look neater.
Related to Help me understand this proof, so I can present it
What is the purpose of this proof?
The purpose of this proof is to provide evidence or support for a particular statement or theory. It helps to demonstrate the validity of the statement and allows others to understand and accept it.
How can I present this proof effectively?
To effectively present a proof, it is important to first understand it thoroughly. Then, you can break it down into smaller, more digestible pieces and explain each step clearly. Visual aids such as diagrams or graphs can also help to enhance understanding.
What if I don't understand a particular step in the proof?
If you encounter a step in the proof that you don't understand, it is important to ask for clarification from the person who presented it or consult other resources such as textbooks or scientific journals. It is also helpful to break down the step into smaller parts and try to understand each part individually.
Can I use this proof to support my own research or theories?
Yes, if the proof is relevant and reliable, it can be used to support your own research or theories. However, it is important to properly cite the source of the proof and acknowledge the original researchers.
Are there any common mistakes to avoid when presenting a proof?
One common mistake to avoid when presenting a proof is assuming that the audience has the same level of understanding as you. It is important to explain each step clearly and provide background information if necessary. It is also important to double check all calculations and make sure the proof is free of errors.
