Help need on windows 7 computer.
In summary, if your cousin formatted your hard drive, you may be able to get your data back by using a data recovery program, but it may be expensive and difficult.
maksim
My name is maksim and this is the first time i am posting question in forums. I am using windows 7 computer which has 250 gb hard drive in it. hard drive has 4 partitions C, D, E and F. Partition C has operating system installed in it which i don't use as told by my friend. The remaining dives are used to save my data. Drive D has important data which is only used by me which has my documents, seminars and projects. Last night one of my cousin (11 years boy) was playing on computer. He was using all options by clicking right click button on mouse. I had gone to have lunch donno what he has done and formatted the entire D drive on my windows 7 computer. The data stored on that drive is really important and i need them daily. I wanted to know what is the procedure to get back the entire drive data?
Computer science news on Phys.org
Depends on the type of formatting done. A quick format just overwrites the pointers to the data but does not overwrite the data itself but a full format overwrites the data as well. If it was a "quick format" then you can pay a professional service to get the data back and it shouldn't cost you too much. If it was a full format, the data MIGHT be retrievable but it would be very expensive to have it done.
On older versions of windows a full format just did a read scan of a partition in order to update a list of bad sectors. I don't know if a full format on current versions actually overwrites the entire partition.
Assuming that most of your data isn't overwritten, it's probably fragmented which may make it difficult to recover. If you wanted to use a data recovery program, you would probably want to buy another hard drive to use for data recovery, and the recovery process could be more complicated than what the recovery program can accomplish. So as suggested, you may be better off using a data recovery company, but that can be expensive.
re-enforcing what phinds and rc said. in most cases you will end up having to send the drive into a recovery specialist and unfortunately, it will be expensive
there are a few tools that may work but i wouldn't be too optimistic, you could give them a try. keep in mind that as you do stuff on the HDD you will fragment the data further thus making files that much harder to recover.
you might try
http://www.piriform.com/recuva
http://www.runtime.org/data-recovery-software.htm
i haven't used these programs myself but found them on a google search. can't garauntee that this will work.for the future, i would suggest setting up separate Administrator and User(Limited) accounts and for normal computer use, be logged into the user account. This will prevent anyone from making a system wide change like formatting a drive without the appropriate passwords. It prevents a lot of user errors that have the potential to break the system.
Hello Maksim,
I understand your concern about your important data being accidentally formatted by your cousin. Don't worry, there are steps you can take to try and recover the data from your D drive.
Firstly, stop using the computer immediately. Any further use or saving of files on the D drive may overwrite the data and make it more difficult to recover.
Next, you can try using data recovery software such as Recuva or EaseUS Data Recovery to scan the D drive and see if any of your files can be recovered. These programs have a high success rate in recovering lost or deleted data.
If the data recovery software does not work, you can also try using a professional data recovery service. They have specialized tools and techniques to recover data from formatted drives, but it can be quite expensive.
In the future, it's important to regularly back up your important data to prevent situations like this from happening again. You can also set up a password or restrict access to certain drives on your computer to prevent accidental formatting.
I hope this helps and good luck with recovering your data.
Related to Help need on windows 7 computer.
1. Why is my Windows 7 computer running slow?
There could be several reasons for a slow Windows 7 computer, such as outdated hardware, too many background programs running, or a virus/malware infection. It's important to regularly update your hardware and run maintenance tasks to optimize your computer's performance.
2. How do I update Windows 7 on my computer?
To update Windows 7, click on the Start button and go to Control Panel. From there, click on System and Security, and then Windows Update. You can then click on "Check for updates" to see if there are any available and follow the prompts to install them.
3. How do I uninstall programs on my Windows 7 computer?
To uninstall programs, go to the Control Panel and click on "Programs and Features." From there, you can select the program you want to uninstall and click on "Uninstall." Follow the prompts to complete the uninstallation process.
4. How do I protect my Windows 7 computer from viruses?
To protect your computer from viruses, make sure to install a reputable antivirus software and keep it updated. Be cautious when downloading and opening files from unknown sources, and regularly back up your important files.
5. How do I reset my Windows 7 computer?
To reset your Windows 7 computer, go to the Control Panel and click on "Recovery." From there, you can choose the option to "Reset this PC" and follow the prompts to reset your computer to its factory settings.
  • Computing and Technology
