Help needed with a mathproblem (first post so I don't know where to post it)
  • Thread starter PaniniBaguett
In summary, the link provided shows a square with an area of 49m^2 made up of 4 rectangles and 1 square. The red rectangle has a circumference of 16m and the green rectangle's circumference cannot be determined from the given information.
PaniniBaguett
http://liggandestolen.files.wordpress.com/2012/01/kvadrat5.jpg?w=450
The AREA of the square in the link above is 49m^2 and consists of, as you can see, 4 rectangles and 1 square. If the red rectangle has a circumference of 16m, what's the circumference of the green rectangle?
Maybe I should add that the 4 rectangles are not of the same size and you can not measure in the picture to get to the right answer.
//PaniniBaguetten :)
I've reported this post, so it should be sent to the appropriate section soon. In the meantime, let's take a look...
Well, you have that the square is 49 m^2, which means that each side of the square is 7 m. We also know that the perimeter of the red rectangle is 16 m. What do you think you can imply from those two bits of data?
FAQ: Help needed with a mathproblem (first post so I don't know where to post it)
What is the math problem?
The specific math problem was not provided, so it is difficult to give a precise answer. However, based on the context of the question, it is likely a question related to a mathematical concept or equation that the person is struggling with.
Where can I find help for this math problem?
There are many resources available for help with math problems. You can try asking a teacher or classmate for assistance, searching online for tutorials or explanations, or visiting a tutor for one-on-one help.
Can you explain the steps for solving this math problem?
Without knowing the specific problem, it is not possible to provide a step-by-step explanation. However, many math problems follow a general set of rules and formulas that can be applied to find a solution. It may also be helpful to break the problem down into smaller, more manageable parts.
How long should it take to solve this math problem?
The time it takes to solve a math problem will vary depending on the complexity of the problem, the individual's understanding of the concept, and their proficiency in math. Some problems may be solved quickly, while others may take more time and effort.
What should I do if I still can't solve the math problem?
If you are still struggling to solve the math problem, don't panic! Take a break and come back to it later with a fresh perspective. You can also try asking for help from a teacher, tutor, or online community. Remember, it's okay to ask for help when you need it.
15K
