Help No net charge inside conductor
In summary, the author argues that there is no charge inside a conductor, and thus, charges are only on the surface.
krismath
Prove that there is no charge inside a SOLID conductor, and thus, charges are only on the surface.
Gauss's Law (Maybe)
I have been doing some research on it on some websites.
It mentioned that, "you make a Gaussian surface inside the conductor. And since we know that the electric field inside any conductor is 0 so there is no charge inside the conductor..."
The problem is that, those websites haven't prove that the electric field inside a conductor is perfectly zero ( which I find mind-blowing ) .
Can anybody provide a proof (preferably mathematical) either that the net [itex]\vec{E}[/itex] inside is zero or that there is no charge inside?
Any help is very much appreciated.
The argument is qualitative.
Take an uncharged conducting solid. Implant one electron in it. It can roam anywhere; there is no force on it anywhere.
Put a second electron on the solid. Now both these charges 'see' each other and repel each other. They will move as far away from each other as possible, i.e. to the surface.
Put a third, etc etc electrons on it, same deal. The all repel each other & so will distribute on the surface.
I suppose you could take the Poisson equation div{grad(V)} = -ρ/ε and E = -grad(V) with the appropriate boundary values to show that ρ = 0 everywhere inside the solid, but I wouldn't know how or even if.
If the conductor is in an electrically steady state, and there is an electric field inside of it, any electrons in the region with an electric field will experience a force and start moving, contradicting the steady state claim
What about the special case of a conductor sphere with an "electron" (let's take it as an idealized classical electric charge, be it positive or negative and absolutely quiet) right at the center of the sphere? Clearly, the E field inside the conductor is not 0 and clearly there's no force applied on the "electron". I agree that it's an unstable equilibrium point, any motion of the charge and it goes on the surface, but still.
Now if you start with the assumption that inside any conductor the E field is null (discarding the above case) then using Gauss law is sufficient I think to prove that any charge must lie on the surface of the conductor. Because [itex]\vec \nabla \cdot \vec E =4\pi \rho[/itex] if E equals 0 then rho must equal 0.
A bit more formally:
axioms:
1)The E field inside any conductor is 0.
2)There's an excess of charge somewhere in the conductor.
"Proof": For any region [itex]\Omega[/itex] inside the conductor, [itex]\int _{\partial \Omega } \vec E \cdot \hat n da=0[/itex] because E is worth 0 there according to axiom 1. Using Gauss law under the integral form, it's equivalent to say that [itex]4\pi \int _{\Omega } \rho d^3x =0[/itex] for any region omega inside the conductor. But for this to happen, rho must be 0 for any region omega inside the conductor. Since we assumed that there was an excess of charge somewhere in the conductor (axiom 2), the only remaining possibility is that the excess of charge lies over the surface of the conductor. End of proof.
P.S.:I used units in which k=1 rather than [itex]\frac{1}{4\pi \varepsilon _0}[/itex].
As the others have observed, usually we take it for granted that the electric field inside a conductor is very nearly zero. This is based on the empirical knowledge that conductors have the special property that there are a lot of relatively mobile electrons floating around, which will rearrange themselves very quickly to restore electrostatic equilibrium if it is disturbed.
So, in this case the net electric force on the central electron may be zero, but it introduces a non-zero electric field that exerts a force on all the other conduction electrons. These electrons will move out towards the surface, inducing a negative charge on the surface. Since there are now fewer electrons near the center, the positive charge from the lattice nuclei are less shielded and they can cancel out the non-zero field induced by your idealized charge. So even if you fixed that charge there mechanically, the conductor would still rearrange itself into equilibrium, if possible.
Thank you very much for these great answer!
FAQ: Help No net charge inside conductor
What is "Help No net charge inside conductor"?
"Help No net charge inside conductor" is a scientific concept that refers to the fact that there is no net electric charge inside a conductor. In other words, the positive and negative charges within the conductor are balanced and cancel each other out, resulting in a neutral overall charge.
Why is it important to understand the concept of no net charge inside a conductor?
Understanding this concept is important for many reasons. It helps explain how electricity flows through conductors and how conductors can act as shields against electric fields. It also plays a crucial role in the study of electrostatics and electromagnetism.
What factors determine whether a material is a good conductor or not?
The two main factors that determine whether a material is a good conductor or not are its ability to allow electrons to move freely (conductivity) and its resistance to the flow of electricity (resistivity). Conductors typically have high conductivity and low resistivity, while insulators have low conductivity and high resistivity.
How does the concept of no net charge inside a conductor relate to lightning?
In the case of lightning, the air acts as an insulator and prevents the flow of electricity. However, when a strong electric field is present, it can ionize the air molecules and create a path for the lightning to travel. This is possible because of the no net charge inside a conductor concept, which allows the electrons to flow freely through the ionized air.
Can the concept of no net charge inside a conductor be applied to other types of conductors besides metal?
Yes, the concept of no net charge inside a conductor applies to all types of conductors, including liquids and semiconductors. In these cases, the movement of charged particles such as ions or electrons allows for the flow of electricity, but the overall charge within the conductor remains neutral.
