Programs Help on Majors and Graduate Degrees as an Engineering Student
The discussion centers on a high school graduate entering the Gator Engineering Program at Santa Fe, which allows transfer to the University of Florida after two years but limits major options. The student is undecided about their major but has a strong interest in physics and is concerned about the feasibility of transitioning to a physics-based master's program later. Key points include the competitive nature of graduate school admissions, the importance of taking relevant upper-division physics courses, and the challenges of switching majors within the engineering program. It is noted that while switching majors is possible, it may complicate the path to graduation due to the structured nature of engineering curricula. Ultimately, careful planning is essential for aligning undergraduate studies with future academic goals in physics.
JurassicJack
I am a high school graduate planning to enter the Gator Engineering Program at Santa Fe. In the program I'll be transferred from Santa Fe to the University of Florida after 2 years. I am very excited for the program but I am restricted by only being able to major in a select few majors.
The majors are: Computer Science, Digital art Sciences, Computer Engineering, Electrical Engineering, Environmental Engineering, Materials Science and Engineering and Nuclear Engineering.
For the program I can switch between these majors but when I transfer to UF it is not a guarantee I will be able to switch out of the major outside of the listed above. I am relatively undecided on what I want to major but I plan to switch around and find what I like.
I do know that I really like physics though, and other areas of science. My family is not the most knowledgeable on college and I am one of the few who is planning to get a higher level degree such as a masters or PhD.
Most of this stuff is unknown to me about how switching majors and I don't know how easy the process would be of getting a bachelors degree in engineering and then a masters in a more physics based major or if that is a feasible plan at all.
So I suppose my main questions are if I do get one of these degrees how easy would it be to get a masters in a more physics based major such as Astrophysics and which one of these majors would give me the most flexibility in getting a masters in a different subject after I graduate. Even though I can switch like I said, I am a Nuclear Engineering major right now
1. To be a research physicist, a masters isn't enough. You need a doctorate. If you are just interested in learning for its own sake, do you need a degree?
2. You will be competing for slots in grad school with people who have a BS in physics. So you want to have as close to the same preparation as they do. That means taking as many of the core upper-division classes as you can (classical mechanics, stat mech, QM and E&M). This may not be compatible with your schedule.
3. You will probably take a class with a name like "nuclear measurements laboratory" or similar. You need to ace it, and you need the prof to write you a very strong letter. This is the closest thing to grad school life you will encounter, and as such it will attract a lot of attention in the applications process.
If your desired end goal is a degree in physics or other areas of science, why are you hopping on to an engineering program whose path leads to a different end goal ... and whose path might not allow you to readily detour to your desired end goal?
"Switching" majors in engineering is generally not that easy to do. While the first year tends to be very general (calculus, linear algebra, physics, chemistry, programming etc.) beyond that, the course sequences tend to be very proscribed and the courses will be very specific to the individual stream. Once you get into the core courses of your stream switching will require you to backtrack and pick up additional courses potentially adding additional time required to graduate.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
