Help please cylinder, torque, rolling w/o slipping problem
In summary, the string exerts a force of 3.2667 N on the bottom of the cylinder. The cylinder will not slip, and the direction of the force is perpendicular to the table.
nchin
172
A massless string is wrapped around a 10 kg cylinder. the picture will look like the letter b. you pull upward on the string with a force of P = 49N. The bottom of the cylinder s on horizontal table and will roll w/o slipping. using dynamics involving center of mass, find the magnitude and the direction of frictional force (f). (no slippage between string and cylinder)Solution:
Torque about cm: RP - Rf = Iα ---> R(P-f) = Iα
I = 1/2MR^(2)
α = a/R
R(P-f) = 1/2MR^(2) (a/R) ---> P-f = 1/2Ma
Forces Horz: f = ma
Why do we need to consider the forces horizontal?? Isn't it already included in the torque calculation?
P-ma = 1/2Ma
P = 3/2Ma
Ma = 2/3P
a = 2/3 (49N) / 10kg ---> 3.2667 N
My teacher got 32.667N? but how?
Solution:
I = 1/2MR^(2)
α = a/R
Forces Horz: f = ma
You have one equation with two unknowns. You need another equation in the same two unknowns.
f = Ma gives you that.
P-ma = 1/2Ma
P = 3/2Ma
Ma = 2/3P
You solved for a and got 3.2667 m/s2 . (You had the wrong units.)
What does that give you for f ?
ooh ok i got it. thanks!
Related to Help please cylinder, torque, rolling w/o slipping problem
1. What is a cylinder?
A cylinder is a three-dimensional shape with a circular base and straight parallel sides. It is similar to a can or a pipe.
2. What is torque?
Torque is a measurement of the turning or twisting force on an object. It is calculated by multiplying the force applied to the object by the distance from the point of rotation to the point where the force is applied.
3. What is rolling without slipping?
Rolling without slipping is a term used to describe the motion of a round object, such as a cylinder, that is rolling along a surface without any slipping or sliding. This means that the point of contact between the object and the surface is stationary at all times.
4. How do you solve a cylinder, torque, rolling without slipping problem?
To solve a cylinder, torque, rolling without slipping problem, you will need to use the principles of rotational motion and apply them to the specific situation. This may involve calculating torque, angular velocity, or other variables using equations such as τ = Iα or v = ωr.
5. What are some real-world applications of cylinder, torque, rolling without slipping problems?
Cylinder, torque, rolling without slipping problems are commonly seen in engineering and physics applications. For example, they can be used to understand the motion of wheels on a vehicle or the rotation of a flywheel in a machine. They are also important in sports, such as in the spinning of a basketball or the rotation of a discus in track and field.
