Help proving with the Binomial Theorem
In summary: BINOMIAL THEORY NOW!In summary, Gauss^2 posted an equation for a sum that is equal to (x+y)n when k is even. When k is odd, the equation gives you minus instead of plus.
steveT
(n¦0)-(n¦1)+(n¦2)-. . . ± (n¦n)=0
that reads n choose zero and so on
Prove this using the binomial theorem
I really have no idea where to start. Any help would be greatly appreciated
thanks
Start by writing down the binomial theorem and seeing how you might get the expression you've typed in out of one side or the other.
What does the binomial theorem tell you? Start there.
That as well.
Well I've been staring at this thing for the past hour and I'm not coming up with anything. Am I to be looking at the (x+y)^n side of the binomial theorem or the side with the summation
Well, which side looks more like
[tex]\begin{pmatrix}n\\0\end{pmatrix}-\begin{pmatrix}n\\1\end{pmatrix}+\cdots\mp\begin{pmatrix}n\\n-1\end{pmatrix}\pm\begin{pmatrix}n\\n\end{pmatrix}[/tex]
steveT, if you write vela's sum expression in sigma notation, the result should jump right out at you.
You might also want to post what expression you have for the binomial theorem. There are different ways to write it, some more suggestive than others.
This is the expression I'm using
(x+a)^n=∑_(k=0)^n▒〖(n¦k) x^k a^(n-k) 〗
OK, so what values could you plug in for x and a such that you'd get the alternating sign but otherwise have them disappear?
(It might help you to expand the summation to make the comparison more straightforward.)
x=1 and a=0 ?
Try plugging that into your equation for the binomial theorem and see what you get. What accounts for the alternating sign?
I know the sigma notation can be a bit sketchy when one first learns it, so let me post this: What does this sum below equal? (according to the Binomial Theorem)
[tex]\sum_{k=0}^n \binom{n}{k}(-1)^k[/tex]
When dealing with sums the dot-dot-dots leave things a bit ambiguous. When you convert a sum with ... into something explicit using sigma notation, it usually makes things a lot easier.
So when k is even you get plus and when its odd you get minus which accounts for the alternating sign.
Expand the summation that Gauss^2 posted. What is it equal to in terms of (x+y)n? You are making this much harder than it has to be.
You know that one side of the equation is zero. When is (x+y)n = 0? Use this along with the binomial theorem. Once you have your x and y, plug them into the formula for the binomial theorem to see if you do in fact get your desired alternating sum.
Yes.
Thanks everyone for your help. I UNDERSTAND
FAQ: Help proving with the Binomial Theorem
What is the Binomial Theorem?
The Binomial Theorem is a mathematical theorem that provides a formula for expanding binomials raised to a positive integer power. It states that (a + b)^n = ∑ (nCr)a^(n-r)b^r, where nCr represents the combination of n objects taken r at a time.
How can the Binomial Theorem be used to help prove equations?
The Binomial Theorem can be used to prove equations by expanding binomials and simplifying the resulting expression. This can help to show that two expressions are equal, which is often a key step in proving equations.
What is the purpose of the Binomial Theorem?
The Binomial Theorem is used to simplify and solve equations involving binomials raised to a power. It is also used in probability and statistics to calculate the likelihood of certain outcomes.
What are some real-world applications of the Binomial Theorem?
The Binomial Theorem has various real-world applications, such as in finance to calculate compound interest and in genetics to determine the distribution of traits in offspring. It is also used in engineering for analyzing circuits and in computer science for data compression algorithms.
Are there any limitations to using the Binomial Theorem?
One limitation of the Binomial Theorem is that it can only be applied to binomials raised to a positive integer power. It also assumes that the variables in the binomial are independent and that the power is a whole number. In some cases, it may not be the most efficient method for solving equations.
