AotrsCommander
- 74
- 4
I am currently writing another entry for a massive lore project (you may have seen the previous thread on the shape of the galaxy).
I am usually pretty good about getting the details accurate (or at least explaining around them), but my sources I am working from to write up are from about 2005-2006 and the understanding (both mine and of astrophysics generally) has improved a great deal since then.
I have managed a reasonable job of re-lensing things with better knowledge, but, as I came to the close of my work-day, I reached this passage (originally from an adventure I wrote), with the pertinent problems highlighted.
If this was a main sequence star, then, obviosuly, at the point it went into the red giant stage, a planet that had evolved life in the main sequence stage would be thown out of it during the giant stage. From my reading, while it is possible for a planet to have developed life during the red giant stage - perhaps even for a few billion years - when the expansion of the star moved the habitability sonze outward, it would not be for long enough to be "among the oldest ecosystems known."
So then, the question becomes how to re-interpret this. (Fortunately, the first thing to note is that this was for a band of adventurers, who, more even that perhaps kost adventurers, were idiots; at least to the point of ths passage being interpreted as their own unreliable-narration-perceptions.)
As the context of the adventure largerly thematically hinges on this being a "really old ecosystem" more than the stellar data, can you suggest to what we might re-interpret what they found.
The star is not not given a classification (that helps!) and we can potentially disgard "main sequence" - PCs-Don't-Read-Astrogation-Data-Properly, so what we would be looking at is a something that would create a very long-term habitable zone.
I initially thought "just use a red dwarf," and be done with it (as they have, as I understand, the longest-term habitability prospects), but THAT presents a problem those generally require a tidelocked planet, which the lfie-bearing on is not (it has a day length of 37 hours, though no year length noted, fortunately).
The second planet (a more venus-life hot world being terraformed by the aliens the PCs were following) is also noted as being closer to the star than this planet. (Following what at the time must have seemed a logical progression.)
Can anyone offet any suggestions on a more accurate way to approach this? (I grant you, with the knowledge available now, the one of the oldest known" is probably not going to be possible (I can to some extent work around that by narravtor bias on the thousand-year old data of course), but I do need a situation whereby a planet, far enough out to be (at least) the second world and not tidelocked, would be able to sustain a (mostly) terrestrial biosphere for an unsually long time.
Suggestions would be very welcome!
This is, as they say, clearly bollocks, because it contradicts itself. Unless I am wrong, it would not be possible for a planet to be in such a position that it could have been habitatable before, during and implied at the close of the main sequence red giant stage.You have entered a system that, surprisingly, is documented in something other than minimal detail, if not well. The system is very old, this vicinity at the edge of the galaxy, being home to the oldest stars. It has no name, merely a designation. It consists of a main sequence single star, now slowly expanding and cooling, before it will eventually collapse into a white dwarf. There are seven remaining planets in the system (how many have been swallowed by the burgeoning star you will never know), three gas giants and four rocky worlds. Two of these – the outer most ones – are merely chunks of rock and ice.
The other two are not.
The first, according to your data – which appears to be over a thousand years old, and complied by a wandering explorer – is a terrestrial water planet with an oxygen/nitrogen atmosphere that is well within breathable limits and is very close to one G; it has a 37 hour day. Life has evolved there, but is very, very old (in fact it is noted as being among the oldest ecosystems known). The world is getting slowly cooler as time creeps on, as the heat from the star is slowly fading. Now, the only equatorial region and it’s attendant continent is free of ice, and the rest of the world is locked in thickening ice. At the equator, the temperature is roughly temperate.
